R60 better belt on the market
Old Nov 3, 2016 | 02:20 PM
CountryS's Avatar
CountryS
I just got my belt replaced by dealership, major loud sound (thinking I needed a new engine), after talking to the mechanic, it seems these belts only last for 24k miles.
Are there better belts on the market that will last longer.
Old Nov 3, 2016 | 03:48 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Mine was not changed until 40k and that was done due to some early signs of cracking and four years of use.
Old Nov 3, 2016 | 04:37 PM
popsrcr's Avatar
popsrcr
The serpentine belt? Never heard of one dying this early on a modern car.
Old Nov 4, 2016 | 03:25 PM
CountryS's Avatar
CountryS
on my last vehicle (GM) the belt was replaced at 150k miles, i'm at 52k miles on my mini and according to the mechanic it's probably the second belt being replaced.
Old Nov 4, 2016 | 04:19 PM
Mini Mania's Avatar
Serpentine Belt
The recommendation is to check the belt after every second oil change. High mileage and even weather conditions can contribute to cracking. In any event, it's fairly cheap insurance to install a new one.
http://new.minimania.com/part/G2NME6...m-Gen2-R55-r61
Old Nov 5, 2016 | 03:08 AM
CountryS's Avatar
CountryS
Thanks for the advice, how long would the belt tensioner be good for, would this item have a longer life compared to the belt.
Old Nov 6, 2016 | 02:50 AM
bmwr606's Avatar
bmwr606
my belt was toast at 4 years ... wear wise it was ok, but it was cracked on both the inside and outside
Old Nov 6, 2016 | 04:28 AM
CountryS's Avatar
CountryS
That makes more sense ... not 24k, I'll track this new one.
Old Nov 10, 2016 | 06:23 AM
bmwr606's Avatar
bmwr606
i winder if there is a Gates green cross reference?
Gates green is their best grade of belts, i have one on my 97 gmc sonoma
i will check with Gates
Old Nov 10, 2016 | 06:49 AM
bmwr606's Avatar
bmwr606
Gates Century Series belt for N18
p/n K060352
length 35 7/8 inches (911 mm)
top width 13/16 inch (20 mm)
Old Nov 10, 2016 | 04:08 PM
CountryS's Avatar
CountryS
Great, I will check them out (Gates Century Series belt for N18), but I will still monitor this belt every second oil change.
Old Nov 10, 2016 | 07:18 PM
grussell's Avatar
grussell
I replaced the belt on our 2012 when I did the clutch job. It was 4 years old, 30k miles and had major cracking. I used Gates.
