replacing rear buckets with bench seat
Subscribe
Apr 10, 2014 | 08:41 AM
is it possible to replace the rear bucket seats with the rail in the middle with the bench seat? Any ideas as to cost?
Reply 0
Apr 10, 2014 | 09:41 AM
Your best bet is to find someone on here that wants to do the opposite and trade seats.
Reply 0
Apr 10, 2014 | 09:43 AM
Quote: Your best bet is to find someone on here that wants to do the opposite and trade seats.
Yeah, that's probably what I'd do, but for now I need to make sure it is possible. I'm helping my gf look for a countryman and there are some nice cars with the bucket/rail, but the bench is a must have for her.
Reply 0
Apr 10, 2014 | 05:30 PM
I'd love the buckets, but I imagine it'd be a difficult swap... don't forget the middle seatbelt off the headliner (and possibly the headliner itself, depending on how that mounts). And the rail (split rail would probably be easier to swap than the long rail).
Reply 0
Apr 10, 2014 | 07:41 PM
I guess you could just buy a 2014 and get the rear bench as standard equipment. I prefer the buckets though as they are more comfortable.
Reply 0
Apr 11, 2014 | 07:17 AM
Quote: I'd love the buckets, but I imagine it'd be a difficult swap... don't forget the middle seatbelt off the headliner (and possibly the headliner itself, depending on how that mounts). And the rail (split rail would probably be easier to swap than the long rail).
Figured it'd be more trouble than it's worth.
Quote: I guess you could just buy a 2014 and get the rear bench as standard equipment. I prefer the buckets though as they are more comfortable.
We are looking for a used one. Probably a 2012...The rail just looks like it'll be way too dangerous for the dogs back there. don't need them breaking a leg.
Reply 0
Apr 11, 2014 | 08:25 AM
Quote: We are looking for a used one. Probably a 2012...
2011 was all buckets, 2012 the benches just started trickeling in. You may have to expand your search to the 2013s. Also, buckets with a flat load floor can be adjusted for an almost flat open space. Need the cover for the way-back pit, fold the seats forward and then the top floor to cover the seat gap. On either side of the rear seats are plastic "ears". If you remove them, there are tiedowns that you can use to run a strap to compress the seats to a more level position. PIA, but it works.
Reply 0
Apr 11, 2014 | 08:31 AM
Quote: 2011 was all buckets, 2012 the benches just started trickeling in. You may have to expand your search to the 2013s. Also, buckets with a flat load floor can be adjusted for an almost flat open space. Need the cover for the way-back pit, fold the seats forward and then the top floor to cover the seat gap. On either side of the rear seats are plastic "ears". If you remove them, there are tiedowns that you can use to run a strap to compress the seats to a more level position. PIA, but it works.
Yeah that's why we're focusing on 2012 or newer. good info on the flat floor thanks!
Reply 0
Apr 11, 2014 | 11:09 AM
As Sealy noted if you have the flat load floor & buckets it will still work. I travel with my 2 Schnauzers that way....
Reply 0
Apr 11, 2014 | 01:41 PM
where are you located?
Reply 0
Apr 11, 2014 | 01:58 PM
i guess we're left to figure out which one of us JWButler's referring to?
Reply 0
Apr 11, 2014 | 03:19 PM
I was talking to the OP.
Sent from my iPhone 5s using IB AutoGroup
Reply 0
Apr 14, 2014 | 02:06 PM
To order and retro fit will be way too expensive ( if purchase at the dealer). I already inquired so from Sewell. I drive a 2013 R60s with the rear bench. My hope is to retro fit the bucket seats. However, nobody seems to know or have the right answer.
Reply 0
Apr 14, 2014 | 02:30 PM
I really cant see how difficult it will be to swap out one for the other. Perhaps if you & the OP are in the same area, you could get together & do the swap...
Reply 0
Jul 24, 2014 | 03:39 PM
Updates?
I'm looking for a used CM as well and the bench is necessary for us. Have found a couple of perfect matches with the options we're looking for, except they have the buckets.
Has anyone tried this out successfully yet?
aaron
Reply 0
Jul 25, 2014 | 03:45 AM
I often remove my rear seats simply with removing the 4 rear nuts and 4 front torx bolts to make more room for my dogs on long trip. I would assume the buckets would fit easily.
Reply 0
Jul 25, 2014 | 04:17 PM
Me too! The rear bench is really the only thing that disappoints me about my 2014 Countryman. Would much rather have rear buckets for the occasional two adult passengers.
Reply 0
Jul 29, 2014 | 06:17 PM
I have a black bench in my 2012. If someone is looking to swap their buckets for a bench, let me know.
Reply 0
Oct 20, 2014 | 07:58 AM
I have the black buckets in a 2011 and would like to swap for a bench
Quote: I have a black bench in my 2012. If someone is looking to swap their buckets for a bench, let me know.
Let me know if you are still interested in a swap. Do you have a 1/2 rail? I have the full rail.
Reply 0
Oct 20, 2014 | 03:59 PM
Quote: Let me know if you are still interested in a swap. Do you have a 1/2 rail? I have the full rail.
I have the half rail. I'm in Minnesota though so shipping would be a problem.
Reply 0
Oct 23, 2014 | 10:41 AM
Have you seen this ? That way you dont have to take out the rear seat, just fold them down. Cool design and protection for the pets and for the MINI.
MINI Cooper Trunk / Boot Protection Space Cover Kit - Priced As Kit 51472179301
http://www.ecstuning.com/Search/SiteSearch/51472179301/
OR
This Universal Rear Seat Cover for animal in just the back seat , in upright potion. 52302179302
http://www.ecstuning.com/Search/SiteSearch/52302179302/
Reply 0
Nov 9, 2014 | 06:51 AM
I have bucket seats to swap
Quote: I have the half rail. I'm in Minnesota though so shipping would be a problem.
I live in the U.P. so we could probably swap in person, if your seat is still available. Question I have is about the configuration of the middle seatbelt. Also, I have the single rail and would like to swap that, too, If possible (as opposed to cutting it myself). Not sure if there are any other obvious differences.
Let me know if you are still interested.
Reply 0
Nov 10, 2014 | 01:18 PM
Quote: I live in the U.P. so we could probably swap in person, if your seat is still available. Question I have is about the configuration of the middle seatbelt. Also, I have the single rail and would like to swap that, too, If possible (as opposed to cutting it myself). Not sure if there are any other obvious differences.
The middle seatbelt is a sticking point. That is mounted to the roof through the headliner, so to do this right you'd need to swap headliners. Just documenting that here for others that are considering the swap.
Reply 0
Nov 11, 2014 | 05:01 AM
I spoke with MINI service as well. So besides changing the seat, the rail and the headliner, there are some parts that need to change with the boot, presumably the plastic molded to fit behind the seats. Finally, though many of you would like to change from bench to bucket as opposed to the opposite, adding the third rear seatbelt to convert to a bench could pose an issue as far as programming it with the car's computer. They felt unsure if the car would accept the seatbelt. If it does not, the seatbelt would not lock in the event of a rapid deceleration or collision.
Reply 0
Nov 11, 2014 | 08:55 AM
Quote: I spoke with MINI service as well. So besides changing the seat, the rail and the headliner, there are some parts that need to change with the boot, presumably the plastic molded to fit behind the seats. Finally, though many of you would like to change from bench to bucket as opposed to the opposite, adding the third rear seatbelt to convert to a bench could pose an issue as far as programming it with the car's computer. They felt unsure if the car would accept the seatbelt. If it does not, the seatbelt would not lock in the event of a rapid deceleration or collision.
Looking at the wiring diagrams for the Countryman, only the front seats have tensioners and only the rear left and right buckles have a connection to the buckle switch.
Reply 0
