R60 R60 Coolant Temp
Old Mar 24, 2014 | 05:31 PM
JFKR60's Avatar
JFKR60
R60 Coolant Temp
I installed a set of Cravenspeed ngauges for coolant temp and turbo boost. They use OBDII plug in and seem to work great and look great. On the coolant temp "normal" operating temp usually runs around 215 degrees F (20-60 degree ambient air). If I switch to sport mode the temperature drops to around 180 within a minute or so. Can anyone explain this?
Old Mar 24, 2014 | 06:32 PM
Steve Kay's Avatar
Steve Kay
If it's an automatic, then I would attribute it to higher RPMs pushing more coolant through the radiator. I'll have to test that out using Dash Command.
Old Mar 24, 2014 | 07:41 PM
chrunck's Avatar
chrunck
It's supposed to do that.
Old Mar 24, 2014 | 09:05 PM
bmwr606's Avatar
bmwr606
on my 03/2012 build all4 the coolant runs 215-225 always ... sport button has no effect, running hard has no effect
Old Mar 25, 2014 | 06:24 AM
chrunck's Avatar
chrunck
Here's a thread about it. I've never monitored temp, so I can't say whether mine does it. From what I've read, it's designed to drop temp in sport mode.
https://www.northamericanmotoring.co...port-mode.html
Old Mar 25, 2014 | 11:50 AM
bmwr606's Avatar
bmwr606
i just tested all combinations of sport button on/off, A/C on/off and driving easy/hard
there was no difference at all in either oil or coolant temp, both stay between 220-230 under all conditions
Old Mar 25, 2014 | 12:17 PM
Steve Kay's Avatar
Steve Kay
Sigh. I wish I was out trying that instead of working. The thread to which chrunck linked has me intrigued. Mine's an auto, so I wonder...
Old Mar 25, 2014 | 01:38 PM
JFKR60's Avatar
JFKR60
Thanks for the comments and the link to the other thread on same subject. I was hoping someone from Mini would monitor these things and provide a definitive answer. Many of the comments make sense - ECU control, etc but would be nice to know the real engineering behind this. At least I confirmed my new gauge is not messed up! Thanks
ryGuyMCS
Oct 6, 2015 12:04 PM
Car Care Products
Sep 22, 2015 06:58 AM
Sep 16, 2015 02:10 PM
Sep 16, 2015 02:09 PM
Gen1Parts
Sep 7, 2015 01:37 PM
