R60 Adding fogs to a Base CM
Old Nov 23, 2013 | 05:54 PM
mikey_t's Avatar
mikey_t
So, what all is involved if i wanted to add a pair of fog/driving lights to my base CM? Note i'm in Canada so daytime running lights are necessary. I'm assuming first off it may be best to go with LED's but the work involved is no where near as simple as my Civic was. I'm more interested in the process though at this point.
Old Nov 23, 2013 | 06:28 PM
cerenkov's Avatar
cerenkov
Do you know if the wiring harness is there?
Old Nov 23, 2013 | 08:12 PM
mikey_t's Avatar
mikey_t
I dont. If the harness was there i would assume it would be fairly easy but i also understand coding changes would need to be made. That's the type of info i'm looking for.
Old Nov 23, 2013 | 09:18 PM
MarioKart's Avatar
MarioKart
Vendor
Super easy. Get burger running in the Kelvin you want. Plug and play and NO error codes. I did mine a week ago
HID on the driver side
Old Nov 24, 2013 | 07:15 AM
chrunck's Avatar
chrunck
Old Nov 24, 2013 | 11:04 AM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by chrunck
Sorry. Order from Burger tuning and pick what color hid you want. 4300k is stock and higher the kelvins the more blue the light is
Old Nov 24, 2013 | 11:50 AM
chrunck's Avatar
chrunck
I thought maybe it was phone autocorrect, but I guess not. I've never seen someone use Kelvin like that. Do you set your thermostat for the Fahrenheit you want?
Old Nov 24, 2013 | 11:55 AM
mikey_t's Avatar
mikey_t
I'm more interested in the process than what lights to buy at this point.
Old Nov 24, 2013 | 12:27 PM
MarioKart's Avatar
MarioKart
Vendor
It's plug and play, super easy. The biggest issue is a kit that doesn't give errors or blink. YouTube I the install.
Old Nov 24, 2013 | 02:28 PM
mikey_t's Avatar
mikey_t
Forgive me for my ignorance cuz i have no idea what a "2013 GP2" is so i dont know what model Mini you have but... is the wiring /connection locations the same in my CM? And do you have a link to your install on You Tube? I seem to be having difficulty locating it.
Old Nov 24, 2013 | 03:34 PM
MarioKart's Avatar
MarioKart
Vendor
PM your cell and I will call you
Mario
Old Nov 24, 2013 | 03:53 PM
cerenkov's Avatar
cerenkov
Forgive me for my ignorance cuz i have no idea what a "2013 GP2" ...
Oh my, heresy...lol. j/k the GP2 is a super and limited version of the JCW hardtop R56.
I'm assuming that you don't currently have fog lights right? There are just blank plugs currently installed?
So if the wiring harness is not there it will be a PITA.
Remove the lower round access panel inside the wheel well and look to see if the harness is present - it will be a few wires with connectors. This will take all of a few minutes to do. If it is present than that part of the installation is simple. Next you will need to add the fog light switch to your panel and then you will need to recode the proper modules.
Old Nov 24, 2013 | 08:14 PM
mikey_t's Avatar
mikey_t
I have drl's there, just not fogs so from that i'm assuming the wiring harness is in place.
Old Nov 24, 2013 | 09:15 PM
cerenkov's Avatar
cerenkov
Ok that will make it easy. This would be very similar to adding the rear fog light.
You'll have to get the switch for the console (not sure what the CM dash looks like) and possibly the trim piece.
Then you may have to do some coding with NCS Expert which is not to difficult. You may have to add the fog light option to your vehicle order to make the switch work.
Non-OEM lights like the ones from Burger may or may not be easier.
Sorry for all the "mays" but I believe that this would be the general process.
jetmechinnc
Nov 16, 2020 06:38 AM
Aug 19, 2015 12:51 PM
Dashdog
Aug 10, 2015 06:17 AM
