R60 Bonnet Stripes fitting instructions
Old Apr 14, 2012 | 11:29 AM
ashanbh's Avatar
ashanbh
Hi All,
I recently bought a pair of bonnet stripes for my White Mini Countryman S All4.
http://www.ebay.com/itm/011-Hood-Bon...item3cc224cd73
Does any-one know, where i could find the proper dimensions/measurements for installing the stripes?
Old Apr 14, 2012 | 02:49 PM
Fly'n Brick's Avatar
Fly'n Brick
Not familiar with the CM but I think if you just lay them out on the bonnet, don't peel the backing off yet, us a little painter's tape to hold them down, and get them in position where you want them they should be just fine. The key idea is 'you-ification' and measure twice. I've replaced my bug destroyed stripes twice now. Very easy to do if you take your time.
Hint: When you get them lined out, fold over some strips of tape and stick them down next to the stripe so the folded part just overlaps. That way you can mark where the edge of the stripe should lie top and bottome.
Old Apr 16, 2012 | 10:43 AM
ashanbh's Avatar
ashanbh
Attempt #1 was a bit of a failure
I tried the dry application method, and had too many tiny bubbles. Think i'm going to try the wet application next.
Thankfully the Ebay decals cost only $35 a pop. Detailed picture coming soon. I will also post the dimensions, if its helpful to anyone.
Old Apr 16, 2012 | 02:39 PM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
Please expand on what you mean by the wet application. I may need to replace one bonnet stripe in the near future myself. Thanks!
Old Apr 16, 2012 | 11:49 PM
ashanbh's Avatar
ashanbh
Wet & Dry Application Method
Here is a video explaining both methods.
http://www.youtube.com/watch?v=3_cO5...eature=related
In particular, i tried something like this.
http://www.youtube.com/watch?v=ymieeZeKr24
However, i ended up with a LOT of bubbles. Here are some pictures.
Old Apr 16, 2012 | 11:57 PM
ashanbh's Avatar
ashanbh
Dray application with bubbles
Also worth noting, that I removed the stripes almost immediately. And, as long as you do it slowly, its fairly easy to remove.
Old Apr 17, 2012 | 12:45 AM
staynedglass's Avatar
staynedglass
2 things could have helped with the bubbles. a hair dryer and a few days in the sun. you will still need the hairdryer/heat gun for the wet method or it will take HOURS for the adhesive to dry enough to remove the paper.
caiken
Aug 27, 2015 06:55 AM
minicoclub
Aug 25, 2015 09:07 AM
blackie
Aug 23, 2015 08:44 PM
bctf1
Aug 6, 2015 12:55 PM
