new owner new problem!! need help ASAP
Old Sep 26, 2006 | 08:59 AM
zipper0879's Avatar
zipper0879
i got up this mornig to go to work and oh sh-- my car would not start i check the battery and even put a charger on it that didn't work but i did notice a clicking sound and i check the fuse panel and everytime i try to start the car there is a fuse that clicks as well this fuse has the gas logo on it is that the pump or what please help
signed stuck at home
thanks
zipper
Old Sep 26, 2006 | 09:05 AM
holdenontoit's Avatar
holdenontoit
tell us a little more about the car: is it new? did you buy it used and if so what is the mileage? sounds like a battery issue which can be as simple as a bad terminal connection to a bad battery.If new,you are entitled to a roadside assisted tow to the dealer. give us some more details.
Old Sep 26, 2006 | 09:27 AM
zipper0879's Avatar
zipper0879
well i thought it was the battery but i had it on a charger all mornig it has 58,000 miles i bought it used its a 02 model the charger shows a full charge and is pulling plenty of amps.
Old Sep 26, 2006 | 09:32 AM
Bosevii501's Avatar
Bosevii501
A lot of times a "clicking" will indicate a bad starter. Usually the starter is trying to fire out the solenoid but the solenoid isn't connecting with the fly wheel. But without hearing it for myself that is only a guess...
Old Sep 26, 2006 | 09:34 AM
holdenontoit
yup.check the two leads to the starter to see if they are tight or dirty.
Old Sep 26, 2006 | 09:52 AM
SumWon's Avatar
SumWon
It might need a new battery. The '02 and '03 models have been experiencing battery failures due to age. A short in the battery would prevent starting, charging, and possibly even jumping.
Old Sep 26, 2006 | 11:05 AM
zipper0879's Avatar
zipper0879
thanks for the speedy response guys i never thought that it would be this easy mini ownera are great!!!!!!!!!!!!!!!!!!!!!
rob&JCW
Feb 13, 2023 07:03 PM
Toolman
Jan 20, 2016 06:50 AM
FrostyFox
Oct 28, 2015 02:06 PM
artguy
R58 :: Coupé Talk (2012+)
Aug 30, 2015 07:56 PM
Zettinger
Aug 25, 2015 04:04 PM
