Need Advice
Old Jul 26, 2006 | 06:53 PM
jdcatron's Avatar
jdcatron
Need Advice
I just purchased my Mini Cooper S and was wondering if anyone here has installed a K&N Air Filter to replace the stock filter.
The guy at the parts counter of my local dealer told me that he has heard of them damaging the Mass Air Flow Sensor.
Any comments?
Old Aug 1, 2006 | 09:33 AM
dominicminicoopers's Avatar
dominicminicoopers
Any comments?
Ask them to explain themselves. You can work them quickly into a corner, when armed with a little knowledge. The air filter is not even close to either of the two MAP sensors the MCS has, so there can be no alarm for damage to it, unless you hire a bumbling mechanic, then anything is game for being damaged. It'd be like saying, oh, "you'll damage the backseats when you install aftermarket wheels", or "you'll damage the radio if you install a center armrest." Get my drift? Anything could get damaged when working on a car.
Old Aug 1, 2006 | 09:37 AM
MINIclo's Avatar
MINIclo
7th Gear Gal
My 2003 MCS had the K&N Typhoon CAI installed in 2004, has 40K miles on it, and it's been great. It never ceases to amaze me what parts persons say to customers...
Old Aug 1, 2006 | 09:39 AM
Boneman's Avatar
Boneman
Actually any filter that you oil (such as K&N) can damage the MAS, but only if you over-oil it when you clean it. It takes very little oil to penetrate the filter so as long as you are careful and follow directions you should have no problem.
Old Aug 1, 2006 | 09:55 AM
caminifan's Avatar
caminifan
The biggest challenge is to not over-oil the filter element. And, yes, if you do over-oil the filter element, you run a definite risk of damaging the MAF. There is a big controversy in the Corvette world about that specific item (over-oiling the filter element). In 2003 & 2004, GM offered a CAI accessory around the K&N filter element. Then, when they started getting failed MAFs (from owners and even service techs over-oiling the filter element), they put out a service notice that stated the problem was with over-oiled filter elements and they would not cover the replacement of the MAF. Guess how much of a s**tstorm that caused? (Especially from owners that bought the accessory kit from the Chevy dealer....)
Old Aug 1, 2006 | 10:08 AM
Gromit801's Avatar
Gromit801
https://www.northamericanmotoring.co...ght=air+filter
There is a foam filter that does not require oiling that is available for Mini's that I saw somewhere on this site. Danged if I can find it though.
Old Aug 1, 2006 | 10:10 AM
dominicminicoopers
But isn't that like saying, you can damage anything if you do something wrong? If done right, there will be no damage to any MAP sensors. What the parts guy was saying is that a normal install of the K&N filter will cause them to go bad. Which is very untrue!
scfiveo
Sep 27, 2019 02:27 PM
rikaro
Nov 24, 2015 02:05 PM
zdw2082
Oct 5, 2015 09:59 AM
bradstyle
Oct 1, 2015 11:15 AM
bahman
Sep 30, 2015 01:59 PM
