Synthetic Oil
Old Dec 29, 2005 | 05:01 AM
DixieHill's Avatar
DixieHill
Synthetic Oil
Anyone know anything about putting synthetic oil in the 's' MINIs? My husband always replaces the oil in our cars for synthetic oil. I don't want him touching my MINI unless I know that is not going to hurt it.
Old Dec 29, 2005 | 05:43 AM
vader's Avatar
vader
Your MINI was delivered with long life synthetic oil. MINI does not support the use of non-synthetic oil.
Old Dec 29, 2005 | 05:56 AM
DixieHill's Avatar
DixieHill
Cool! Thanks. I guess when we take delivery we'll find out things like this. I don't know anything about the engine I just love the car!
Old Jan 10, 2006 | 01:10 PM
anteken's Avatar
anteken
They don't change the oil for 10k. Would recommend you pick up a filter and have it changed around 5k...just make sure u use Synthethic.
Cheers
Old Jan 10, 2006 | 02:06 PM
Coopernicus's Avatar
Coopernicus
I really like the way you think Anteken .
...BUT... I have to ask... can you replace just the filter on a MINI without getting swamped by oil pouring out of the filter housing? I only have 1100 miles on my '06 MCS so far, so I haven't changed oil yet, and haven't investigated the orientation of the filter housing.
BTW - I have run Mobil 1 Full Synthetic oil exclusively in ALL of my racing and street engines for 20 years WITHOUT regret. Having seen engines torn down after many hours of use (and - in some cases, abuse), I can tell you that TRUE, FULL Synthetic oil is worth every penny.
Old Jan 10, 2006 | 04:03 PM
Motor On's Avatar
Motor On
I'd reccomed the thread about castrol out, mobil one in; as there is lots of good information about when, how and what to use when it comes time to change the oil. I know many change the oil at the end of the break-in.
Old Jan 10, 2006 | 04:17 PM
innymini's Avatar
innymini
Pretty sure that Mobil 1 is not a FULLY synthetic oil - may consider Redline, Amsoil, or Royal Purple
And I would get that oil out after 1K or 2K miles - motor is pretty much broken in.
Old Jan 10, 2006 | 04:46 PM
RockC's Avatar
RockC
Probably not broken in... While I can't speak with any experience with a MINI, with other cars following the owners manual break-in guidelines it is clear from the engine's gradual loosening up that break-in continues even after the break-in period. Also at least one car company did lab and field studies and found that engines fuel economy increased even up to 10,000 miles had accumulated on the engines in test as the engines broke in and internal friction dropped which the company interpreted as evidence of a longer the spec'd break-in.
I think it is a good idea to change the initial oil/filter at 1000 miles, unless the owners manual specifically forbids it. A new engine sheds a bunch of trash (metal particles, sand, etc.) and if the filter plugs up, this dirty oil bypasses the filter and is simply directed to the engine's main/rod bearings and other critical areas lubed by the oil.
Even if the filter continues to filter the oil, the oil becomes full of tiny particles that can exact a wear penalty on the valve gear. Some car makers as valve gear becomes ever more complex (variable valve timing and lift) add a second filter -- on a bypass oil path - to filter out the smaller particles the primary filter can't.
Lastly, it is not a good idea to as soon as the break-in time has passed, to begin hammering on the engine with the old dirty oil in place. To me this simply undoes any thing gained by following the maker's break-in guidelines for accelerated engine wear can't help but occur. The oil's not only dirty with stuff shed by the engine's internals, but is more heavily contaminated with fuel and water (and other combustion byproducts). (Too, even more applicable to the MINI, supercharged (and turbo-charged) engines generally experience more blowby that normally aspirated engines.) Gas and water contamination work to lower the oil's viscosity and compromise its ability to adequately lubricate under high load, high heat conditions.
Sincerely,
RockC.
Old Jan 10, 2006 | 09:37 PM
Coopernicus
Wrong answer.
Both standard Mobil 1 and Mobil 1 Extended Performance are FULL SYNTHETIC, non-blended oils. Always have been.
Read it for yourself:
Mobil 1 Information <-- click here
However, the "Mobil Clean" variants ARE indeed synthetic blends, and they do not claim otherwise on the MobilOil site. The other oils you mention are all exceptional full-synthetics as well, but can rarely be found anywhere near the price of Mobil 1 because they all tend to cater more to racers then the general public.
Old Jan 10, 2006 | 10:48 PM
Rollin's Avatar
Rollin
According to this thread, and some others on NAM, not all synthetics are created equal (this is the thread mentioned by motor on; https://www.northamericanmotoring.co...ad.php?t=58053
Old Jan 11, 2006 | 07:39 AM
Iggy-MCS's Avatar
Iggy-MCS
Coopernicus - The best way to chagne the filter on the mini, is to unscrew the filter housing just a bit until you hear the filter seal break, then when you drain your oil, you also get most of the oil out of the filter housing before you even begin to remove it. Because of the two part (housing and filter element) design of the BMW/Mini filters, it's a much better experience than on most cars. But you need a darn big wrench to be able to grab the flats on the back of the filter housing, i think like 34 mm or something like that.
Old Jan 11, 2006 | 10:32 AM
Coopernicus
Thanks for that info. I just test-fit a 36mm socket on the filter housing, and it seemed to fit perfectly. That is the same fitment as the oil filter cap on my last car, a Porsche Boxster S, so I got lucky by already having the right tool for once.
Also, since the filter housing is mounted fairly high relative to the oil pan, it would appear that you can crack open the filter housing WITHOUT draining the oil first and the rest of the oil will NOT pour out through the filter housing - is that right? I HATE big, synthetic oil slicks on the floor of my garage !!
Old Jan 11, 2006 | 02:43 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Yes, the oil filter housing takes a 36mm socket. I bought mine for $7 at Sears.
As mentioned earlier in this thread, remove the oilpan plug and let the oil drain. When it's about stopped, slowly loosen the filter housing until you break the seal and oil starts draining out. Go away for another 10 mins or so. When the oil has stopped coming out of the pan again, remove the filter housing. If you do a sort of wrist twist and tilt the opening upwards as you take it off the threads, you should be able to remove the housing without spilling a drop.
Enjoy.
Old Jan 11, 2006 | 03:21 PM
Coopernicus
Good info Agro - thanks.
Old Jan 11, 2006 | 03:34 PM
Yucca Patrol's Avatar
Yucca Patrol
Enjoy.
If only I was so lucky. . . I usually end up spilling a teaspoon full. . . .
Old Jan 11, 2006 | 04:22 PM
MGCMAN's Avatar
MGCMAN
Then you've got one awfully large serving set.
Old Jan 11, 2006 | 04:29 PM
Agro's Avatar
Agro
My 1st oil change (5000 miles) I spilled nothing, the 2nd one I did myself (17500 miles after the dealer did the 10k) I got impatient, didn't let the housing drain, and spilled a bit under where Alice usually parks.
From now on, patience will be exercised when changing the oil.
Old Jan 12, 2006 | 07:43 AM
Rollin's Avatar
Rollin
Is the 36mm socket and procedure the same for the MC and MCS?
Old Jan 12, 2006 | 10:57 AM
Agro's Avatar
Agro
I believe that the MCS and MC use the same filter housing and location, so yes.
Oh yeah, the 36mm socket that everyone keeps talking about having to cut shorter, I had no problem using in the exact condition I purchased it in.
It's a craftsman socket, and I use it with a craftsman socket wrench.
Old Jan 12, 2006 | 11:34 AM
Yucca Patrol
Same here. I use the standard Craftsman socket and the fit is no problem at all.
Old Jan 12, 2006 | 08:50 PM
Coopernicus
Same Craftsman 36mm socket here, and there seems to be plenty of clearance for a socket wrench accessed from the top on my '06 MCS.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 03:01 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 09:05 AM
