Engine swap
Old Aug 1, 2023 | 02:17 PM
trini's Avatar
trini
Engine swap
I had an accident with my 2005 Mini Cooper S. The left rear quarter panel is destroyed. Other than that the car runs great.
I have a 2003 body (automatic) and I was wondering whether it is possible to put the 2005 S engine and gearbox into this car
this is the damage to the 2005 S
My plan is to drop the engine from the 2005 S with the sub frame and install it in the 2003 body.
Remove the complete electrical harness from the 2005 and install it in the 2003
Will this work? I will have everything I need for the swap in the 2005 which has a lot of new parts (3 months old) The S engine was completely rebuilt by me about 6 months ago and a new clutch and pressure plate was also installed by me.
If this can be done, I would appreciate some advice as to the issues I may run into.
Thanks, Frank
Old Aug 1, 2023 | 02:19 PM
trini's Avatar
trini
Bodyshop wants $ 4000 to replace the quarter panel. That is a lot more than the car is worth, hence the idea of swapping the engine into my 2003 mini.
Old Aug 2, 2023 | 06:44 AM
gauss66's Avatar
gauss66
I'd post this in the first gen mini driveline secion
https://www.northamericanmotoring.co...n-cooper-s-16/
Old Aug 2, 2023 | 07:48 AM
trini's Avatar
trini
Thanks. I will do that.
Old Mar 8, 2024 | 10:55 AM
cooper48's Avatar
cooper48
In addition to the wiring harness, you'll also need the ECU from your wrecked Mini. Maybe someone can also weigh in here but you may also have issues with the wiring harness compatibility with the boot harness.
Stephen Johnson
Aug 10, 2020 08:55 AM
rbennett
Aug 12, 2019 12:48 PM
Sokol
Jul 4, 2019 03:58 PM
v_o
Jun 14, 2019 02:45 PM
jeffle
Jul 20, 2018 06:47 PM
