Newbie Here, R56 Crank no start
Old Mar 23, 2023 | 02:28 PM
RossTaylor's Avatar
RossTaylor
Hello from Florida. I've got a 2008 Cooper S recently acquired (broken). Pulled the head, new valves, timing components, etc.
But Crank, no start. Pulled out the Scope and did some probing. no crank signal. Verified power and Ground at Injectors,
finally thought the DME was hosed. Sent it off with the CAS for testing. Got a call back today that both checked out good, they installed
them in their test car and sent me a video of my components installed in a running car. They are sending the components back
and I will reinstall this weekend. At this point, I have a new crank position and a known working good DME. The obvious next thing
for me do dive into is the wiring harness. I do have ground at the valve cover block. Surely I'm missing something obvious or
I have a broken wire....
Oh, I did the relay check and bypass and checked the fuse block for water damage and burned pins
Any guidance would be greatly appreciated. (also lookin for a complete DME pinout)
Thanks,
Ross
Old Mar 24, 2023 | 05:53 AM
RockC's Avatar
RockC
Supply 12V power to the fuel pump to see it if runs.
Old Mar 29, 2023 | 05:26 AM
mural's Avatar
mural
My passenger side was FLOODED.. dried everything out but still no start. I jumped the relay with a paper clip and got it running now time to replace JBE.
snaptube vidmate
Old Apr 3, 2023 | 07:47 AM
Yep, the JBE aka Fuse Box SPEG High might be back order.
Szel
Sep 11, 2022 07:51 PM
Shields Racing
Apr 28, 2022 03:23 PM
broxclubman
R55 :: Clubman Talk (2008+)
Oct 21, 2021 04:40 PM
Wookie
Mar 5, 2014 07:50 PM
