Fault codes
Old 12-30-2019, 04:28 PM
Scott Marcle's Avatar
Scott Marcle
Scott Marcle is offline
Fault codes
I have received a Carly OBD reader for Christmas so I plugged it into my 2012 Countryman S and it found 7 fault codes. Does anyone know a way to find out what they mean?
002C57 boost pressure control, plausibility:pressure too low
00321C tankentlueftungs - and purge air fine leak: leakage pressure greater than 1.0 mm
002DD0 valvetronic system: exceeded warning threshold deviation
0028A0 throttle angle - absolute pressure suction, comparison pressure too,low
002BC0 mixture ECU: mixture too lean
00A8aD : parking light right defective. - I have replaced this bulb.
any help will be greatly appreciated.
scott Marcle
803-391-0920
smarcle@icloud.com
Old 01-02-2020, 03:09 PM
Chevycruizer's Avatar
Chevycruizer
Chevycruizer is offline
Is your check engine light on?
If not just clear them out and see if any come back. Often a code is stored for just a one time momentarily undesired condition and it is could be nothing to worry about.
If you get the same codes back then look into finding the solution. Just my 2 cents.
Old 01-03-2020, 10:06 AM
ECSTuning is online now
Received 1,979 Likes on 1,776 Posts
Yep, clear them and see what returns after a drive.
scolburn79
01-08-2013 04:47 PM
jmoser
07-29-2008 02:21 PM
camelpilot
08-19-2006 08:12 AM
d2mini
Electrical
10-10-2005 02:58 PM
silver-mini-s
06-15-2004 08:34 AM
Quick Reply: Fault codes
