Lever by oil filter
Old Oct 8, 2019 | 07:25 AM
alahawg's Avatar
alahawg
Lever by oil filter
I just got an 2013 mini cooper s and was changing the oil and there was a lever that I had to move to get the filter out. I can see it has a cable but can't find where it goes.
Old Oct 8, 2019 | 08:47 AM
Hello, Can you post a pic?
Old Oct 8, 2019 | 09:00 AM
alahawg's Avatar
alahawg
I didn't take one (will try to do better next time). In your picture the lever by the extension with the bar code on it..
Old Oct 8, 2019 | 09:03 AM
Thats the transmission lever/balance, you can select a gear and it should move out of the way. I have gotten the filter out without moving it.
Use a flex end adapter and an extension with a schwaben 27mm socket 6 point and it comes right out easy. Like the picture above.
https://www.ecstuning.com/b-schwaben...drive/s-1227s/
Old Oct 8, 2019 | 09:06 AM
alahawg's Avatar
alahawg
Old Oct 10, 2019 | 01:41 PM
You are welcome. Place a towel underneath, close to the filter cap and it will catch the oil so it does not drip on the front of the transmission and the aux water pump.
crappie_fisherman
May 18, 2011 11:12 AM
FranticFreddy
Apr 24, 2010 07:48 PM
thewrongguy
Mar 25, 2010 05:25 AM
dwm
Jun 19, 2007 09:59 AM
sirron
Aug 5, 2002 08:33 PM
