first time mini owner, new problem
Old May 7, 2019 | 03:33 PM
petedavis's Avatar
petedavis
Hello Everyone,
my wife bought a 2013 cooper S (r 56 i think) about a yr ago, everything was going great until today, the car on the lift light came on in red, turn signals, left and right brake lights, hazard lights and windows all stopped working, can someone point me in a direction to make repairs ?
thanks in advance
Pete
Old May 7, 2019 | 03:37 PM
ItsmeWayne's Avatar
ItsmeWayne
Hi Pete,
Checking with an OBD2 scanner would be your best way to find out, but I will tell you there has been issues with the ignition switch. A 13 Cooper 3 is a good car with a good engine, so I would not freak out.
Possible one of the major fuses could have gone also.
Check the common problems area on here and maybe it will take you to the fix!
Welcome to NAM!
Old May 7, 2019 | 03:52 PM
petedavis's Avatar
petedavis
thanks, i have been looking around on other threads but do see a problem quite like mine... who can do that scan, any place that scans or does it have to be a dealer?
Old May 7, 2019 | 04:47 PM
ItsmeWayne's Avatar
ItsmeWayne
I recommend, that everyone that owns a car (Mini) have one. There are several out there. I carry mine in the car ( ICarSoft ) and carry a Blue driver with my truck. Easy to plug in and read with a smart phone (@ about 100 bucks) It is money well spent and can get you out of trouble when you are on the road! (It works with Mini also)
You can take it to Autozone and they will scan for free, but they are not very good at diagnosing!
Old May 7, 2019 | 06:01 PM
petedavis's Avatar
petedavis
went to autozone and no codes showed up, i got a better run down of what doesnt work, turn signals, high beams, fog lights, left and right brake light ( third brake light works), turn signals, hazard lights, interior lights, ambient lights..... i checked fuses, they are good, there is a relay thats in with the fuses that was extremely hot, but the relay isnt listed on the back of fuse cover
Old May 7, 2019 | 06:45 PM
petedavis's Avatar
petedavis
after some research, it sounds like the FRM took a crap
Old May 7, 2019 | 08:10 PM
ItsmeWayne's Avatar
ItsmeWayne
Many times Mini Coopers will have poor grounding due to corroded grounding. They ground from two main areas. 02 to 08, which are on the passenger side wheel well (a bolt with many wires connected) It should be removed and the body and terminal should be cleaned. On the inside under the carpet at the center hump, there is another grounding of many wires on the terminal. The same thing should be done there too!
On lighting, bulbs should be checked and if old replaced.
Old May 9, 2019 | 07:20 AM
Did you scan the car which the schwaben tool? Did you test a new FRM?
PurpleCMS
Jan 4, 2019 10:52 AM
Stanley Holtsclaw
Jun 20, 2014 10:44 AM
Prim12MINI
Apr 7, 2013 07:39 AM
Venteren
Aug 21, 2010 10:44 PM
Texidian
Oct 15, 2006 04:24 PM
