Engine mount
Old Jul 13, 2017 | 02:46 PM
maximus16v's Avatar
maximus16v
Engine mount
Hi All! Can someone verify if this is the correct engine mount for an 04 S? I'm ordering all 3 online and when I look at this specific one on the car it looks like it doesn't have that sort of bracket (just a round mount). And I believe I have seen one similar without a bracket on a different parts website. Can anyone confirm?
Old Jul 13, 2017 | 04:29 PM
Whine not Walnuts's Avatar
Whine not Walnuts
What year and model is your car?
Old Jul 13, 2017 | 04:52 PM
RB-MINI's Avatar
RB-MINI
That's a face-lift passenger frame rail mount for 2005-2006 coupes and 2005-2008 convertibles. Not sure if late 2004's started using them. If your mount doesn't look like that it should be the earlier mount. Here's a pic from the Pelican Parts article on replacing the engine and trans mounts. The two pieces on the left are the early style upper passenger side mounts along with a bracket connecting the two. Not sure if it's recommended to replace the mounting bolts for the early style like on the later face-lift mounts. All pieces can be ordered from Pelican if needed. The replacement how-to article is here:
http://www.pelicanparts.com/techarti...eplacement.htm
Old Jul 14, 2017 | 08:05 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Shoot me the last 7 digits of your R53's vin number as it is dependent on your MINI's build date.
Here is what our catalog says: http://www.pelicanparts.com/catalog/..._pg3.htm#item8, but will need to confirm with your vin.
888.280.7799 | 6am - 5pm PST
Old Jul 14, 2017 | 08:45 AM
maximus16v's Avatar
maximus16v
Thanks guys! Unfortunately I'm up I Canada so found a local online parts place so I don't have to deal with customs and duties. The only one they seem to have is the 05+ one. Wish I was in the US and could just deal with Pelican.
The last 7 digits are TD76662
Old Jul 14, 2017 | 08:51 AM
PelicanParts.com
Vendor
Not a problem - would rather you get the correct one. According to real OEM and your vin you'll need part number 22-11-6-760-448, which looks like the image below. You can also take a peek at yours under the hood to make sure it looks like it has the same rubber outside vs. the one you posted in your original post.
Old Jul 14, 2017 | 09:03 AM
maximus16v's Avatar
maximus16v
Ya I checked before and that's what prompted the question. The one online didn't seem right with that bracket. I will check again though. The other one (lower left in pic RB-MINI posted) is the correct one as well. Haven't been underneath to see the other one but I imagine that one will be the same as well?
Thanks again for all your help!
Old Jul 14, 2017 | 09:08 AM
PelicanParts.com
Vendor
Yes, 22-11-6-756-405 (lower left in image above and #8 on the diagram above) is the one for your MINI. Happy to help.
Khai
Jun 1, 2017 08:37 AM
jkim1201
May 31, 2017 01:39 PM
ajstefanacci
May 10, 2017 06:21 PM
Filmy
Sep 21, 2016 11:59 AM
bbarlow641
Sep 9, 2016 12:02 PM
