rear wheel bearings
Old Mar 23, 2015 | 02:16 PM
really huge's Avatar
really huge
rear wheel bearings
I suspected a bad bearing when I bought this car. Mechanic lady dealt with put it on hoist and put scope on front wheels, said they sounded fine. Possibly a rear wheel bearing. Is there any way to test for that?
Old Mar 23, 2015 | 03:04 PM
Tarmac Junkie's Avatar
Tarmac Junkie
With the car in the air, see if the wheel has play in it. This is the easiest way to see if the wheel bearing is bad. Could still be bad if no play is felt, but this is an easy first step.
John
Old Mar 23, 2015 | 04:27 PM
really huge
Will do. At least it's a start.
Thanks!
Old Mar 27, 2015 | 10:40 AM
Listen and spin the wheel on the lift or rack and compare it to the other side, listen for a low grumble noise and you can sometimes feel the roughness of the bearings while you spin it.
For Gen 1 MINI the year split was in 7/2006 production for the part numbers . So keep that in mind.
www.ecstuning.com
Old Mar 27, 2015 | 01:25 PM
really huge
too late
Got aftermarket bearings shipped, good, needed larger diameter bolts..bad.
Live and learn. Bolts overnight delivery will be done in the morning. Gotta watch, lots of vendors say exact fit, which they may be, doesn't mean it'll go back together.
wkp1219
Nov 13, 2015 07:52 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
