R53 ECU Remap Question
Old Apr 13, 2013 | 08:52 AM
Jasta12's Avatar
Jasta12
Hi - I recently acquired a 2004 R53 and I am looking to do some power upgrades. I plan on installing a cold air intake which seems straightforward, not quite ready for a pulley upgrade but am interested in an ECU Remap. In Seattle I have only seen 92 and 89 octane but the upgrade calls for 93 or 91 octane. Does anyone know if the 91 octane ECU upgrade will work with 92 octane gas?
Old Apr 13, 2013 | 10:55 AM
ZippyNH's Avatar
ZippyNH
YES
You can map a car for lower than the planed octane, but not higher.
A canned tune (non-dyno) will not get you much....maybe a bit.
With a pulley, and a custom dyno tune, you might hit 200 HP.
The further a car is from the stock, the MORE you gain from a tune. The closer to stock...the less the gain.
The MINI ECU is amazing adaptive...and actually does fine with a 15% pulley....
Old Apr 13, 2013 | 12:30 PM
astroBlackMetallic_Mini's Avatar
You'll spend way more on a tune than a pulley, and then pay for a re tune after you get the pulley anyway. Tunes are usually last.
Old Apr 13, 2013 | 01:19 PM
ZippyNH's Avatar
ZippyNH
And a suggestion....
Stay away from "the SHARK INJECTOR".
It is mostly a timing advance..and for a pulley'ed car...and HAS caused some issues for many...typically burnt valves.
Old Apr 13, 2013 | 10:03 PM
Jasta12's Avatar
Jasta12
Thanks all for your info, it's helpful in planning my projects. I hope to install the cold air intake in about a month, looks like the pulley upgrade will be the next project.
Old Jun 26, 2013 | 09:17 PM
juggerknot89's Avatar
juggerknot89
Hey Jasta12,
I was wondering which "canned tune" you decided to go with. I'm considering the madness stage 2 ecu. (URL below)
http://www.madnessmotorworks.com/mad...reupgrade.aspx
Since the Shark Injector apparently is a bad choice I was hoping you might have some suggestions on what you decided to use.
Old Jun 27, 2013 | 03:08 AM
Minian's Avatar
Minian
Mynes/Bytetronik
http://mynesperformance.com/
iggi
18
Feb 9, 2026 01:00 AM
andrewjg1994
Jan 29, 2021 07:45 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Aug 21, 2015 11:18 AM
Emnotek
Aug 13, 2015 05:47 PM
