Passenger door
Old May 23, 2012 | 02:53 PM
davidj8's Avatar
davidj8
Passenger door
My 2006 Mini's passenger door will not open from the inside. The door lock is working so I think the actuater is ok. Any thoughts??
Old May 23, 2012 | 05:02 PM
ACEkraut11's Avatar
ACEkraut11
Most likely the cable release slipped out of its holder. Take it apart and check it out. Really pretty easy to do. You might try banging on the door panel. If it is close it MIGHT pop back in.
Old May 23, 2012 | 05:32 PM
fatboy97's Avatar
fatboy97
Check out some of the YouTube video about changing out the stock handle for a pull strap type... they take the door apart and show you the lock assembly and will show you how it works. They say it takes about 10 minutes per door, so I'd double that to take yours apart and see whats working and what is not.
Old May 23, 2012 | 07:06 PM
davidj8's Avatar
davidj8
Thank you for the suggestions....
Old May 23, 2012 | 07:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If it works otherwise most likely it's the cable, sometimes they just pop out the actuator but we still replace them.
http://www.waymotorworks.com/bowden-door-cable.html
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Southern Marylander
Sep 3, 2015 05:46 AM
Ntety
Sep 2, 2015 08:39 PM
spackletooms
Sep 1, 2015 10:12 PM
