Changing out the hood scoop on a 2009 S
Should be the same as my 07. One torque screw (plastic), remove it. There are about 8 little clips. Just use something to slip between the scoop and the metal bonnet and carefully pry upward. If I remember correctly they aren't really clips but a plastic pin with a **** on the end that sticks into another plastic hole insert.
Hood scoop heat shield? Thinking of picking up the JCW CF scoop... but would still like the heat shielding you are referring to. Any addtional info appreciated.
http://www.outmotoring.com/mini-coop...at_shield.html
I see the heat shields listed with the scoops online , there is a fabric insulator on the bonnet now, whats the diff between the new heat shield on line and the one on there now? Thanks for your reply. : )
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
O4mcs
Aug 10, 2015 10:22 PM
jrezzo
Aug 9, 2015 10:32 PM
