NAPA an O.E. parts, part numbers, info inside!!
Old Jan 21, 2012 | 06:09 AM
Noir2005's Avatar
Noir2005
Just wanted to give everyone a heads up about NAPA Auto Parts. Since last year, we started using a company called Altrom to get more European/Japanese market parts, and after Purchasing our 2005 Noir Mini (black/black) I've been researching like mad to make sure I don't get the dreaded call from the wifey that she's having problems. After crossing the Number Altrom used, I found out that NAPA carries all the O.E. filters, and pretty reasonable too! ( In a lot of cases the O.E. is cheaper then NAPA's own suspension and filter parts, as for our Mini's our prices are pretty close sans the coil.) Just make sure you go to a Corporate company, and not a franchise, as most cases they are not under the contract to get these.
Here's a list of part numbers to ask for, and if not in stock, can be ordered, our warehouses are being stocked up as we speak, and only took a few days to get in. and FYI, they use MINI's stock numbers, not their own.
MINI - 2002/2007 (Non-JCW)
Oil Filter - MANN - HU816/2X
Air Filter - MAHLE - LX1269 ( Cooper S)
Air Filter - MAHLE - LX1046 ( Base)
Cabin Air (w/o charcoal) - Meistersatz - 64311496710
Cabin Air (w/ charcoal ) - Meistersatz - 64311496711
Spark Plugs - NGK - BKR6EQUP
Plug Wires - Bosch - 09799
Coil Pack - N/A - 12137510738
Inner/Outer Tie Rod assembly - Lemforder - L2711701 (Left)
Inner/Outer Tie Rod assembly - Lemforder - L2711801 (Right)
Ball Joint (Lower) - Lemforder - L2538402 (Left)
Ball Joint (Lower) - Lemforder - L2538502 (Right)
Control Arm (w/o ball joints) - BMW - 31126761409 (Left)
Control Arm (w/o ball joints) - BMW - 31126761410 (Right)
Control Arm Bushing (Lower) - Lemforder - L2532001
Sway Bar Link (Front) - Lemforder - L2552202
Sway bar Link (Rear) - BMW - 33506772789
Strut Front (w/o sport suspension) - KYB - K334621 (Right)
Strut Front (w/o sport suspension) - KYB - K334622 (Left)
Strut Rear (w/o sport suspension) - KYB - K341924
Strut Mount Front (upper) - KYB - KSM5443
Strut Mount Rear (upper) - KYB - KSM5444
Hub/Bearing Assembly Front - Cooper-Bessemer Engine - 31226756889
Hub/Bearing Assembly Rear - Cooper-Bessemer Engine - 33416756830
Brake Rotor Front - Zimmerman - 34111502
Brake Rotor Rear - Zimmerman - 34211503070
Thermostat - Facet - 11531485847 (O.E. 195.8 F / 91 C)
Wiper Blade Set ( w/ wind deflector) - Bosch - 3397118541
Water Pump ( Natural Aspiration) - BMW - 11517513062
Oxygen Sensor ( Front/Rear) - NGK - 25648
Brake Pad Wear Sensor Front - BMW - 3435671447
Brake Pad Wear Sensor Rear - BMW - 3435671448
ABS Sensor Front - BMW - 34526756384
MINI - 2007 - 2009 ( Non-JCW)
Oil Filter - MANN - HU711/51X (From production date 4/07)
Air Filter - Mann & Hummel - C37100 ( Automatic)
Air Filter - Mann & Hummel - C5082 (Manual)
Cabin Air - Mann & Hummel - CUK4436 (Activated Carbon Type)
Sway Bar Link Front - Lemforder - L2552202
Sway Bar link Rear - BMW - 33506772789
Brake Rotor Front (280mm) - Zimmerman - 34116774985
Brake Rotor Front (294mm) - Zemmerman - 34116774986
Brake Rotor Rear - Zimmerman - 34216774987
Thermostat - BMW - 11537534521 ( O.E. temp 221F/105C)
Brake Pad Sensor Front - BMW - 34356783230
Brake Pad Snsor Rear - BMW - 34356783772
Oxygen Sensor Front (N/A) - Bosch - 17114 - (To production date 2/09)
Oxygen Sensor Front (N/A) - Bosch - 17217 - (From production date 2/09
Oxygen Sensor Front (Turbo) - Bosch - 17112
Oxygen Sensor Rear - NGK - 25198
MINI 2010 + - Not Available at this time
There are a ton of brake pad options, so instead of listing them all, speak to a local NAPA Auto store for what you're looking to run, make sure to ask for Altrom pads. the selection is PBR, Textar, and Pagid.
We also carry the CHF11S power steering fluid, Pentosin Antifreeze (with the silicates) and Valvoline CVT synthetic trans fluid that is compatible with the O.E. fluid. Unfortunately, the only thing I didn't find was the trans filter, those numbers have been discontinued in our system :(
Also, thought there are no immediate numbers and availability for 2010+ Models in my system, that doesn't mean I can't cross the numbers, or call my Altrom sales rep, and see what the time frame is for those numbers to come in. Every month we're seeing updates for new stuff, so over time we will be carrying those.
For those looking for JCW filters, our NAPA gold series filters do have a listing on a few of them, if anyone is interested in the part numbers, just let me know. Also if anyone has any numbers they may want, or to find out if we carry them, just let me know, I'm here for 10 hours a day, so I have plenty of time to look it up for you
Old Jan 22, 2012 | 08:20 AM
klricks's Avatar
klricks
Since you refer to your '05 MIINI I would assume that your part # list refers only to 1st generation MINI?
Old Jan 22, 2012 | 09:39 AM
Noir2005's Avatar
Noir2005
My apologizes, correct, this is for the first generation. I will compile the newer generations on Monday for anyone who may be interested.
Old Jan 23, 2012 | 06:42 AM
Noir2005's Avatar
Noir2005
Post updated with new numbers /\ /\
Old Jan 24, 2012 | 07:54 AM
Noir2005's Avatar
Noir2005
More updates! Maybe mods would like to sticky this?
Teh
Aug 22, 2022 04:37 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
ltjpunk7
Sep 6, 2015 07:32 AM
vanhick
Aug 19, 2015 09:03 AM
