Need help ASAP
Old Oct 23, 2011 | 01:53 AM
steveo54472's Avatar
steveo54472
Need help ASAP
My friend has a 2006 mini s, i did a brake job all the way around yesterday, now the cars parking brake is very loose, it will hold but there is no tension on it whatsoever, any help here would be awesome.
Thanks in advance, Steve
Old Oct 23, 2011 | 03:50 AM
vader's Avatar
vader
Two thoughts/questions:
When you compressed piston in the rear calipers, did you rotate them or just force them in?
Is is possible that the emergency brake cable slipped out of its holder on one of the rear calipers?
Old Oct 23, 2011 | 04:29 AM
steveo54472
no i have the full rear caliper tool set, everything seemed fine when i was screwing them back in, both sides went on and together smoothly, when i went over the vehicle before leaving the garage and putting the tires back on everything looked normal, no hanging cables or anything, im kinda at a loss here, minis are not my specialty
Old Oct 23, 2011 | 04:30 AM
steveo54472
just kinda hoping its something simple, which it usually is, but i just wanna make sure
Old Oct 24, 2011 | 08:30 AM
KochDeutsch's Avatar
KochDeutsch
My first thought is that maybe only one side is engaging (since it still holds but has no tension). Check the cables at the caliper end first, then check at the lever end.
AZ R53
GP Talk
15
Sep 22, 2015 06:17 PM
wlfman13
Sep 17, 2015 10:05 AM
wyliec0y0te
Sep 15, 2015 01:13 PM
potterstein
Sep 11, 2015 11:45 PM
USA-RET
Sep 8, 2015 01:50 PM
