Mini Cooper set up
Old Apr 18, 2011 | 03:29 PM
Petty Pablo's Avatar
Petty Pablo
Mini Cooper set up
In the process of looking for rims and tires for my 2007 mcs I like the tenzo 18x8 rims wondering if they would be to wide? I have factory set up.
Old Apr 18, 2011 | 03:40 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Look for the correct offset, and they shuld. Use the search button^
Old Apr 18, 2011 | 03:46 PM
Petty Pablo
I don't want to sound like a idiot but I don't kno wat that means far as correct offset please educate me on that. Thx
Old Apr 18, 2011 | 04:55 PM
DICKS GARAGE R53
Offset is how centered the hub will be in the wheel. The 4X4 guys call it backspacing which is a little simpler of a term to grasp. You want to make sure that your 8" wide wheel, even though wider than the stock wheels, keeps the same amount (or as close to the same amount) of tire behind the face of the hub. If there is too much the tire will hit the suspension or other parts, but too little backspace will make your wheels stick out like a bean waggon. You want your extra wheel with to be in front of the hub, but the wider you go, the more they will stick outside of the fenders. With a 8" wide wheel you would poke the tires out a little bit.
SosoMINI
Nov 22, 2015 03:17 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
MiniJess
Aug 10, 2015 09:51 PM
jrezzo
Aug 9, 2015 10:32 PM
