Transmission Fluid Change 2005 Mini Cooper S Steptronic
Old Feb 12, 2011 | 10:42 PM
GKoutek's Avatar
GKoutek
What kind of transmission fluid should I use? There appears to be two automatic transmissions used in the MINI Cooper and MINI Cooper S models.
One is the Steptronic 6 speed automatic, the other is the CVT. I believe the MINI Cooper S has the Steptronic 6 speed automatic. Mine has paddle shifter levers on the steering wheel. I can manually shift in the SD mode, which is when I move the floor shift lever to the right, although if I don't choose to shift using the paddle levers on the steering wheel, the transmission will automatically do so at a higher RPM than if I leave the floor shift lever in the normal mode. Should I use D4 ATF Redline fluid, or should I use Red Line CVT fluid? Another possible choice I've been told is Bilstein Febi A/T fluid. How much fluid does it take to change it, even though it seems they would have you believe it doesn't ever need changing. I have 93,000 miles on the car. Also, what about changing the filter? Is there a different filter for the two transmissions?
Old Feb 13, 2011 | 06:31 AM
Suzanne's Chili Red S's Avatar
This thread may help:
https://www.northamericanmotoring.co...id-change.html
Old Feb 13, 2011 | 02:53 PM
Crashton's Avatar
Crashton
Do NOT use CVT fluid. It is not correct for your car.
iggi
18
Feb 9, 2026 01:00 AM
phrza81
Oct 10, 2015 11:37 PM
jrezzo
Aug 9, 2015 10:32 PM
joelcseymour
Aug 7, 2015 12:43 PM
