2003 Mini cooper S not starting
Old Jan 23, 2011 | 01:38 PM
lovnlf's Avatar
lovnlf
I am having issues starting my mini. It had sat without being started for around 6 months. I bought a new battery for it since the old one was bad. All lights come on but when I push in the clutch and turn the key nothing happens - not even a click. I am thinking it's the starter but not 100% on that. Any ideas would really be appreciated. Thanks.
Old Jan 23, 2011 | 02:14 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
In cases such as these I would check fuses first.
Even the fuse module in the boot's battery box.
Was there no battery or a dead battery in the MINI all that time btw ?
Old Jan 23, 2011 | 02:16 PM
KnottyMan's Avatar
KnottyMan
Do you at least have 12V to the positive terminal in the engine bay? While not to the starter, it's at least in the general vicinity.
If you have a helper, or failing that, position a meter so you can see the voltage and then turn the key. Drops to 0? No change? I'm wondering if you have a bad connection between the front half and back half of the car since the battery is remote.
Could be bad clutch switch?
I think there's a 100A fuse on the bottom of the fuse box for the starter?
Trying to think smaller/easier before tearing into getting to starter.
iggi
18
Feb 9, 2026 01:00 AM
TREX
Nov 2, 2019 07:31 PM
SosoMINI
Nov 22, 2015 03:17 PM
joelcseymour
Aug 7, 2015 12:43 PM
