looking at higher mileaga 1st gen cooper S have questions.
Hi,
Im looking for a 1st gen cooper s as a commuter. at my budget they are higher mileage 1st Gens @ about 80K to 110K miles. I would appreciate an advice. Im pretty hands on and can do a lot of DIY repairs/maintenance
Questions.
-What should I look out for.
-Is there a page to FAQ and DIY's?
-what is this Strut mushroom issues, is there a fix if I find one w it.
-Can I run it another 100k miles without a bunch of failures?
Basically i drive about 25000 miles a year and need a reliable car without a lot of failure. Hoping CooperS can fit this bill.
TIA for any advice ..
Questions.
The best source of information on buying a used first generation can be found at www.motoringfile.com just below the ads in the upper right hand corner.
Control arm bushings wear out
P/S lines leak
Oil pan gaskets leak
Pass side motor mounts fail
Clutch feel good?
Upper strut mounts broken?
These are the first things I would check cause they are the most common.
P/S lines leak
Clutch feel good?
Don't forget the door sill rust issue.
andrewjg1994
Jan 29, 2021 07:45 PM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
jrezzo
Aug 9, 2015 10:32 PM
