power steering rack
Old Sep 8, 2010 | 07:05 PM
kellini's Avatar
kellini
power steering rack
Does the power steering pump have to be replaced if the rack needs to be replaced? thanks
Old Sep 8, 2010 | 07:45 PM
Grassroots Garage's Avatar
Grassroots Garage
No, but I would flush it and make sure there is no metal flake in the fluid. If there is, you will want to replace the reservoir which contains a filter.
Old Sep 9, 2010 | 06:13 PM
kellini's Avatar
kellini
power steering rack
Thanks, dealer says leak in right side of p/s rack causes vibration in car. I don't feel it. What would cause a vibration with just a little slit, not even enough to leak on garage floor. Dealer says to replace p/s pump and fan also.
Old Sep 9, 2010 | 08:44 PM
Calz's Avatar
Calz
The P/S rack can leak on the outter seals and all the fluid will sit in the inner tie rod boot. Never seen this where it would cause a vibration though
If the P/S fan seizes up or is inoperable the P/S pump can overheat.
Or if the P/S rack leaks out the fluid and you run the pump dry this can also damage the pump
Old Sep 10, 2010 | 06:54 AM
kellini's Avatar
kellini
Will I need an alignment after the rack replacement? Thanks
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
