Supercharger Pulley
Old Jun 19, 2007 | 04:42 AM
GMAN58's Avatar
GMAN58
Supercharger Pulley
I understand I can change the Taper Bore Pulley associated with the supercharger to boost horsepower however there is a 15%, 17% and 19% unit available and I am not sure which one I should choose. My 2005 Cooper S is driven every day on the street. Any recommendations here on type and OEM product best suited for my needs. Also does changing this pulley affect the manufacturers warranty on the vehilce?
Old Jun 19, 2007 | 04:49 AM
ignote's Avatar
ignote
I would recommend the 15% pulley. It's the one most used and probably the safest.
Yes. Changing the pulley could likely affect the warranty. But don't let that stop you. It really is a great mod for these cars and the likelihood that it will cause you a problem is quite rare.
Old Jun 19, 2007 | 04:58 AM
daflake's Avatar
daflake
Pulley will more than likely void your warranty. There are MANY threads on this...
As notes the 15% is the safest and gives a nice boost to the car.
Old Jun 19, 2007 | 03:07 PM
GMAN58's Avatar
GMAN58
Thanks for the input. I will look into this to see what I can find out.
Old Jun 19, 2007 | 03:17 PM
Eric_Rowland's Avatar
Eric_Rowland
Note that the OEM is a friction fit pulley, which is replaced with either a taper bore or a 'direct torque' collar which clamps to the SC shaft.
15% is accepted and safe.
Higher numbers get more boost - how well that translates to power depends on your equipment and RPM range.
Warranty all depends on your dealer.
Old Jun 19, 2007 | 03:21 PM
bamatt's Avatar
bamatt
I recently put a 15% pulley on my MCSC & it is a DD. I really really like it & think it is the greatest mod for the moolah IMHO. I have 1-1/2 years left on my warranty & I know they can try to be azzes if they wanna but I don't think I would get denied any warranty work unless it's on my supercharger
Old Jun 19, 2007 | 03:26 PM
Eric_Rowland
Your convertible has big tatas, or your pulley?? Sorry, your sig did it...
DD = Definite Do??
Old Jun 19, 2007 | 03:28 PM
mozzarella's Avatar
mozzarella
Superchargers are cheap anyway.
Old Jun 19, 2007 | 03:31 PM
bamatt's Avatar
bamatt
DD = Definite Do??
ta-tas is sooo yesterday can't you see I've moved on to hooters While DD may very well be someones cup size it is my daily driver
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Mb460
35
Sep 18, 2015 06:46 AM
Alanberto
Sep 16, 2015 07:25 AM
Mb460
Sep 14, 2015 05:50 AM
Emnotek
Sep 11, 2015 04:16 PM
