10th Annual MINIs On The Dragon (May 2 - 6, 2012) MOTD 2012
MOTD Schedule for iCal
Old Jan 9, 2012 | 10:15 AM
amberback's Avatar
amberback
I've created iCalendars that can be subscribed to with all MOTD events. This should work with iCal and Outlook and on most smartphones.
I separated them to make them a little easier to view.
Day Drives: CLICK HERE or download the .ics
General Events: CLICK HERE or download the .ics
Old Jan 9, 2012 | 11:07 AM
jcauseyfd's Avatar
jcauseyfd
Fails with Google calendar for me. Due to robots.txt being blocked.
Old Jan 9, 2012 | 11:47 AM
amberback's Avatar
amberback
I'm not sure how to get around that... It looks like google calendars is blocking the iCloud robots.txt... it should work in Outlook and Yahoo calendars.
Old Jan 9, 2012 | 12:52 PM
jcauseyfd's Avatar
jcauseyfd
Actually, that would be Apple blocking access to the robots.txt file.
Maybe I'll just build the calendar using Google.
Old Jan 9, 2012 | 01:03 PM
amberback's Avatar
amberback
I opened it in Outlook and then exported it... does it work if you download the ics file and import it? http://dl.dropbox.com/u/12306966/MOTD%20Events.ics
Old Jan 9, 2012 | 01:17 PM
jcauseyfd's Avatar
jcauseyfd
It looks like the import works, but the only item that comes thru is an 8:30 entry for today.
Old Jan 9, 2012 | 01:20 PM
amberback's Avatar
amberback
I'll try exporting it from home then. Outlook and I don't get along.
Old Jan 9, 2012 | 01:33 PM
jcauseyfd's Avatar
jcauseyfd
Cool. I already have the drives calendar put together in Google. Will work on the other events later.
Old Jan 10, 2012 | 05:50 AM
amberback's Avatar
amberback
Added links to download the .ics, if google likes that better.
Old Jan 10, 2012 | 06:21 AM
jcauseyfd's Avatar
jcauseyfd
Here are a couple versions I created:
MOTD 2012 Drives
MOTD 2012 Events
These were created in Google Calendar as the iCloud versions can't be imported into Google calendar (and I was having trouble with Thunderbird on my PC). These may be useful for folks on other platforms.
They are the .ics versions - I usually use .xml and can make that available if someone wants them.
The calendars I created are public, so not sure, but you should be able to find them if you do a search (I've never searched for a public calendar on Google, so not sure how that works).
MC36
Jan 1, 2019 06:53 AM
BenjiFace
Dec 20, 2015 06:56 AM
krohm
Sep 28, 2015 12:16 PM
Helix13mini
Sep 18, 2015 12:52 PM
