Thinking of upgrading to Enkei PF01
Assuming you have stock suspension and 2002-2006 Cooper S hardtop.
Enkei Racing PF01 in 17x7" has an offset of 45mm which is nearly OEM, you'll need to ask for a set of centering rings to use to fit the MINI's 56.1mm hub bore. Check with the vendor, tirerack will provide the plastic rings to fit at no additional cost.
From http://www.enkei.com/size_chart/PF01.pdf
The PF01 in 17x7" with 4x100 bolt pattern also comes with offset of 38mm which will make the wheel stick out by 7mm more than when offset is 45mm.
Compared to OEM wheels the 38mm offset pokes out 13mm more or about 1/2". some owners like the wheels to stick out and be closer to flush, take your pick.
Tirerack stocks the 45 offset wheels to match OEM fitment.
Both offsets will work with stock suspension, your choice. No real difference in performance, slight potential difference in wheel weight due to different wheel spoke design for the offsets.
Not having to run wheel spacers is preferable, plus you can use the stock wheel bolts. Wheel spacers may need longer wheel bolts or change to long wheel studs.
If the wheel is 7" wide then a 205mm wide tire will fit correctly and the spokes will not stick out (at all). If you are using a very wide rim and a narrow stretch fit tire then yes, the rim edge can stick out, usually the spokes don't stick out.
see
http://www.discounttire.com/dtcs/infoWheelOffsets.do
MINI wheels have negative offset. The larger the number the more the wheel is located towards the inner suspension.
I understand how off set works, but what I am questioning is the design of the PF01 wheel itself.
Do the spokes and center of the wheels extend beyond the lip of the wheel; its hard to find a photo that reflects this view.
Also, some comments we're made that the +38 may weigh slightly more due to the design; how does this wheel design differ from the +45 that causes this ?
At $265 each I want to make sure this is the wheel I am looking for to have on my Mini.
Also, how do these wheels stand up to normal street driving, not including large pot holes that can ruin any wheel.
For all the replies and comments, Thanks a lot ! Its all good info !
07-16-2020 12:54 PM
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
10-24-2018 01:20 AM
Navigation & Audio Impedance of Stock Under-Seat Speakers
jnrjr79
Navigation/Audio
18
09-18-2015 05:51 AM
sabjcw
08-14-2015 07:40 AM
