MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Suspension
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
  #51
Old 01-15-2008, 06:17 PM
AstroBlackS's Avatar
AstroBlackS AstroBlackS is offline
Gallery
Looks like a good deal,
If you want the green ones:
http://www.outmotoring.com/mini-coop...g_springs.html
  #52
Old 04-03-2008, 08:17 AM
Pablo Pablo is offline
Gallery
Quote:
Originally Posted by 911RSAmerica View Post
I just installed a set of PSS9's in my 05 MCS. I set the ride height in
the middle of the permissible adjustment range, measured for the top
edge of the spring seat down to the center of the bottom mounting screw.
Front permissible adjustment range 210-230mm set at 220mm drop LF 1 3/16" RF 1 1/4"
Rear permissible adjustment range 175-195mm set at 185mm drop LR & RR 1 1/16"
The permissible adjustment front and rear is 20mm so from the middle setting the car
can be raised or lowered 10mm (0.394")
The Drop range is:
Front ~7/8 to 1 5/8"
Rear ~5/8 to 1 1/2"
David K.
David or any other PSS-9 owner,
I'm mulling over linear springs for the front but when I went to my toolbox for the install instructions, they were gone. I know the bottom measuring points are different between the front and rear and are illustrated in the instructions. So, does anyone have the instructions that they could scan and email?
I'm also trying to figure out the correct inside diameter (2.25", 60 mm or 2.5") and also the uncompressed length and the length with full car weight on the wheels.
Any help will be greatly appreciated.
Paul Evans
  #53
Old 06-12-2008, 02:19 AM
07BPB's Avatar
07BPB 07BPB is offline
Gallery
I just bought some King Springs for my MC and ill measure before and after. Just to see if the info holds. And you spelt Australia wrong next to King Springs in the first post
Daisy the '06 R50
Too many mods to count
  #54
Old 06-15-2008, 01:25 AM
07BPB's Avatar
Gallery
Yeah, I installed the king springs today on my MC. I had about a 1 inch drop front and rear. They are still fresh and on the drive home i noticed the front had settled more.
Daisy the '06 R50
  #55
Old 04-23-2009, 07:21 PM
ponie5 ponie5 is offline
Gallery
hey out there...
i have h-sport springs with 90,000+ miles on them on my 03 cooper s. as i consider replacing them can someone please give me an opinion/comparison on h-sport vs tsw springs? i am running koni fsd shocks which i really like. didn't bother with camber plates but probably should have as my tire wear is always a problem. also, i do tire of scaping the ground so often ....
  #56
Old 11-21-2009, 08:35 PM
MINICHEF's Avatar
MINICHEF MINICHEF is offline
Send a message via Yahoo to MINICHEF
Gallery
anyone have information about the Koni Sport springs?
I know they state a f/r drop of 30mm, but what about spring rate?
2005 BRG/W JCW
MOTORING ID: TWIST001
MMC#313
WWW.CUSTOMMINISHOP.COM
"Racing is life. Everything else is just waiting" - Steve McQueen
  #57
Old 01-28-2010, 10:21 AM
drfubar drfubar is offline
Gallery
Quote:
Originally Posted by ponie5 View Post
hey out there...
TSW springs will be higher than the H-sport, so u wont scrape. How are your struts after 90k?
  #58
Old 04-20-2010, 08:15 PM
jimmyd1's Avatar
jimmyd1 jimmyd1 is offline
Send a message via AIM to jimmyd1
Gallery
Hey guys I got the mini mania stage 1 suspension kit with the 2mm sway bar and Vogtland lowering springs. I put them on and they were supposed to produce a 1 inch drop as well as provide better handling. The rear is lowered as promised but the front is still at stock height. Is there something that I missed? I made sure everything went back together properly and even got it aligned and Firestone said everything was put back properly but I don’t understand why the front didn’t get lowered. If anyone has any ideas please let me know
Nology hot wires,msd coil,NGK iridium plugs,15% redux pulley,Invidia cat back,CAI,PIAA MESH 18'son bridgestone potenza R760 tyres,Mini Mania stage1 suspension springs/sway bar,M7 shock tower bar PIAA lights too much appearance mods to name PM ME W/U R Q'S (ANYTHING)http://miniclubofwny.activeboard.com...picID=27499190
http://www.facebook.com/home.php?ref...nport?ref=name
  #59
Old 04-25-2010, 06:16 AM
101101's Avatar
101101 101101 is offline
Send a message via AIM to 101101
Gallery
If someone can measure the stock ride height (either ground to jack pucks or wheel center to the wheel well arch) I can measure the drop TSWs give on my car.
  #60
Old 04-26-2010, 05:22 AM
jimmyd1's Avatar
Gallery
Quote:
This may or may not help you I have a 2004 MCS (R53) and the front measures 25.5" from the center of the wheel arch to the ground the back is 25.25. I just put the mini mania stage 1 suspension kit on which consisted of a BRK 22 mm rear sway bar and Volkland lowering springs. I know my rear is lower but my front is still at the stock height and I am working to figure out why this is. Do you have any suggestions?
  #61
Old 07-28-2010, 02:23 AM
wrh3 wrh3 is offline
Gallery
Some data on the Apex (Holland) spring rates:
Drop: 30-40mm
Linear rate, like OE, NOT progressive like some others
The fronts are approx. 185 lb/in (I don't know if this accounts for the stopper which adds some to the rate)
The rears are approx. 215 lb/in
http://www.billswebspace.com/mcs.htm...gsHotchkisRCAs
Bill - 2005 MCS
BMW Car Club of America
  #62
Old 09-16-2010, 10:16 AM
MinItaly MinItaly is offline
Gallery
Hello guys, i have a question...which spring is more CONFORTABLE between H-Sport, TSW and Tein h-tech?
And which spring is better for Handling?
I put the ride on second hand...
I Know that Eibach and H&R are very hard/rigid (which is the appropriate word?) but i know nothing regard the others...
P.S: Now i have Bilstein B8 with stock spring, handling and confort are good but the wheels gap is too much!
Sorry for wrong english
  #63
Old 09-20-2010, 06:01 AM
Gallery
  #64
Old 09-29-2010, 05:09 AM
Gallery
Nobody?!?
  #65
Old 04-13-2011, 10:48 AM
Gallery
Nobody can help me???
  #66
Old 04-13-2011, 12:00 PM
Gallery
I am currently running the same Bilstein Sport dampers you are with my Apex springs, it is PERFECT- handling and looks :-)
Bill - 2005 MCS
  #67
Old 04-29-2011, 11:57 AM
blueflash blueflash is offline
Gallery
The rates for the M7 progressive spring is 219 front, and 224 rear. The claimed drop is 1.3". I hope this helps fill in the table!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
