Suspension Which sway bar bushings?
Old 09-09-2016, 09:20 PM
66stang21's Avatar
66stang21
66stang21 is offline
My front sway bar bushings are being replaced under an extended warranty on my 2012 S. I decided to take this opportunity to put in an Eibach sway bar (yes I know it won't make a huge difference in the front) since they have to take the subframe out anyway.
In doing so, I don't know which bushings to go with. I have two sets. One is the poly set from Eibach that is not greaseable (meaning no zirk fittings or grease channels) but it has some sort of fabric molded into it where it will contact the bar. The second choice is a greaseable poly from Prothane. The Protuane is a bit stiffer than the Eibach and it's also smoother and has the grease channels.
Does anyone have any experience with this? Suggestions?
My mini is simply a weekend warrior / date night car.
Thanks in advance!
Old 09-10-2016, 02:12 AM
neonsteve's Avatar
neonsteve
neonsteve is offline
Thanks in advance!
I put the Eibach front and rear sway bars in my R55 and wrapped the bars with Teflon tape and used the supplied grease. Big mistake. The rear bar was okay/quiet unless it was near freezing then I'd get creaking and popping noises. I disassembled, cleaned and regreased the Eibach bushings and that solved the problem in the rear. The front bar was pretty quiet except it would creak going over speed bumps, I had it disassembled cleaned and regreased. It's a little better now but apparently had some wear. I should have installed new bushings rather than just regrease the fronts.
Don't use Teflon tape. I think that the non greasable polyurethane bushings from Eibach are fine. I've heard Way Motor Works comment that sway bar bushings typically do not need to be regreased.
Old 09-10-2016, 08:49 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Just use the bushings that came with the sway bar you'll be fine
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Tennmoto1
10-23-2016 07:47 PM
TJANK
08-18-2016 02:55 AM
Drnickm53
08-17-2016 06:57 AM
gfx
R55 :: Clubman Talk (2008+)
08-16-2016 08:14 AM
TJANK
08-15-2016 11:28 AM
Quick Reply: Suspension Which sway bar bushings?
