No gears after transmission swap
Old 07-01-2015, 07:15 PM
William Armstrong's Avatar
William Armstrong
William Armstrong is offline
2002 Mini Cooper was 5 speed, swapped in a 6 speed following he guidance at http://personal.stevens.edu/~jdunn/FixingtheWeakLink.pdf
Problem is now only have 1st gear. I know it could be a huge number of things but if you guys can help get me looking in the right direction that would be tons of help.
Old 07-01-2015, 08:37 PM
CGaboury's Avatar
CGaboury
CGaboury is offline
you swapped over the linkage and everything from a 6 speed right? Can you verify that moving the shifter into the second, third, etc gear inside the car actually translated to the linkages moving at the transmission? Sounds like either you have your linkages screwed up, or the transmission you installed was no good. Was the transmission known by you to be fully functional?
Old 07-02-2015, 06:49 PM
William Armstrong
Help
Are the shift cables the same between the non "s" 5 speed and the s- 6 speed. The shift box is the white condition a.
Old 07-02-2015, 09:41 PM
CGaboury's Avatar
CGaboury
CGaboury is offline
I don't know if they are the same linkage. But I'd think they are different. You probably should look into that. Didn't your tranny swap tutorial mention it?
Old 07-03-2015, 08:43 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
The shift cables are different so you need the 6spd S cables.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 02-10-2016, 12:27 PM
Mini Stan's Avatar
Mini Stan
Mini Stan is offline
Yep- just did the swap. Cables are DEFINATELY different. Get the "S" cables.
Old 02-11-2016, 07:00 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
What shift base do you have, black or nylon white/yellow color ? And what year was the donor car it came from? Or last 7 or the VIN ?
Old 02-11-2016, 07:56 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
OP probably figured it out by now seven months later, at least I hope so.
mellocooper
R55 :: Clubman Talk (2008+)
07-21-2016 05:05 PM
maestro39
10-27-2015 02:38 PM
MiteyF
08-26-2015 05:07 PM
Ryephile
08-25-2015 06:51 AM
Colt45Magnus
08-12-2015 06:43 AM
Quick Reply: No gears after transmission swap
