Valve cover gasket HELP
on
Removing And Installing, Sealing Cylinder Head Cover (COOPER S)
Remove intercooler.
Remove bolts (1) securing left hand bracket and remove bracket (2).
Mounting screws for mounting (Left) of intercooler to intake manifold
M6 9 Nm
Remove bolts (1) securing right hand bracket and remove bracket (2).
Mounting screws for mounting (Right) of intercooler to intake manifold
M6 9 Nm
Disconnect hose (1).
Disconnect PCV valve (2).
Disconnect connector to coil pack (3).
Remove plug caps (twist and pull) (4).
Remove harness clips from inspection cover bolts.
Remove coil pack.
Remove 12 cylinder head cover bolts.
Remove cylinder head cover.
Install hint:
Replace cylinder head cover gasket if necessary.
Clean mating faces with a suitable material.
Note: Cylinder head cover fixing screws are separate from the cylinder head cover.
Replace retaining screws and insulators if damaged.
Install hint:
Install cylinder head cover and tighten screws to sequence.
Cylinder head cover to cylinder head 12 nm
The Cooper engine is the same less the IC of coarse
Remove intercooler.
M6 9 Nm
M6 9 Nm
Remove coil pack.
Install hint:
Install hint:
I just attempted to change out my valve cover gasket and it just wasn't working out. I got the bentley manual that gives pretty much the same description as above but for the life of me I could not get the valve cover off. It just would not clear that plastic cover to the fuel rail. The two tabs that the plastic engine cover click into to be specific. I have an automatic.... does that make a difference? Any tips? I really don't want to take it to the dealer. do i have to take the fuel rail off?
It's a cooper and the gasket is leaking. I am planning on replacing the plug tube seals also but I just can't get the cover off. There has to be something I am missing here. Two of the front bolts are partially covered by this plastic cover for the fuel rail. I have to jam a socket in there to unscrew them but that is the area that won't clear.
At 91K miles pulled #1 spark plug and noticed dripping oil from the electrode....then checked the bottom of cyl tube and saw oil. Same but not as bad for #2 cyl.
Tube seals were shot. Replaced along with a new valve cover gasket.....
FYI - Like most of the MINI's nuts and bolts the valve cover bolts often are pretty corroded and can be difficult to remove.... I would order up some from MINI to have on hand before tackeling this job. There are several different types of bolts which hold it down.
But for the sake of being thorough, I ordered all 12.
no choice but to at least pull this cover off for me... The nuts holding mine on in the front are completely rusted away. I figure I will just take it all off and clean it up while I am in there... Pix def. appreciated guys!
I was doing my detroit tuned BPV when I noticed the nuts were all but missing (just some dust left)...
Leaking valve cover gasket
I have 35K miles on my 08 clubmanS and it has a leaking valve cover gasket. Now that I am out of warranty how much should it cost to get fixed? I extended my warranty last year and hope it will be covered under that extension from Mini. The warranty is with mini.
