Navigation & Audio Anyone get the new portable NAV?
I just ordered one from my dealer. I chose it because I like the clean look. My '04 MCS doesn't have NAV and my wife gets lost easy. This is a bit more money than 3rd party, but I like the integration.
Anyone have pics of how this looks? Mine is supposed to be installed later this week. I wanted one last option to return it, in case it looks like junk.
If it's the one that is in the new brochure it looks to be a Garmin Nuvi 350. I bought a nuvi 660 for the ballpark of the dealer 350 unit. Nothing against the dealer one, just liked the widescreen better. One thing, if you get it, is there are several of us on here that would like the file for the MINI vehicle displayed on the screen. Actually, I would like the dealer listing myself. We would appreciate it if you considered posting them.
So I'm the Guinea pig! I can do this...I just liked the real integrated look of the dealer install. I think I was sold on the special mounting bracket they claim to use which perfectly fits our vehicle. I'll have to look at this in more details before I approve the install.
Are these files on a CD or in the unit? If they are in the unit, how can I access them? Copy them to and SD card or can the unit plug into my PC and be accessed? Haven't used one of these type units before (normally get integrated NAV), but I'm surely tech savvy enough to make it happen...
The file are on the unit itself and as Nor_Cal_Mini posted the car is an SRF file. Should be easy to retrieve.
If you can post pictures of the mount. My unerstanding is that it used te normal Garmin windshield mount (which is actually a very good mount, except in Cali). If there is indeed a custom mount I think there are alot of us that would like to know about it and the part number for it (usually stamped in it if it is a special mount).
Sorry, for all of the info and requests but we are curious to the setup since there have only been pictures. I inquired at 2 dealers about it and both did not know much. In the respect of information I guess you are the Guinea Pig.
To get the .SRF files off of the Nuvi, you just connect the Nuvi to your computer with a mini-USB cable, at which point it will show up as a browseable external drive.
Fortunately, that's not correct! You can download the free POILoader from Garmin's site and manage the POIs that way. They've even got a Mac version, now! The POI databases are really just discrete files that can be copied to and from the nuvi at will, but unfortunately the Garmin software *requires* that the device be plugged into the computer in order to even start up, which is kind of silly. There's a third-party program for the Mac that allows you to compile the POI files and manage the file copying yourself.
"POI Loader does not create customized POIs, nor is it software for your Garmin GPS. It simply gives you the ability to upload POIs created by others from your PC to your compatible Garmin"
So while it's useful, the functionality of POI Loader isn't quite the same as what you used to get with MapSource. As for the third-party programs that allow you to create POIs, I'll admit I don't know everything that's out there, since I just use the copy of MapSource I already have. Still, it's nice to know there are other options.
This http://www.motoringfun.com/2007/04/0...tem-in-action/ or the portible:
http://www.motoringfun.com/2007/03/1...gation-system/
Both reviewed: now to choose with one, remeber the portible includes the MINI on the screen with changable tops, english accent, and of course it says MINI.
Probably a topic for another thread, but between Google Earth and gpsvisualizer.com, you should be able to put together your own list of POIs pretty easily. Export your points from Google Earth and then use gpsvisualizer.com to generate a CSV (or better yet, GPX) file, then import that with the POILoader.
Just curious if you got the nav installed? Details, pics or any other info you have?
Yeah, I did and posted a bit on another thread about it.
I really like the install and think that the brochure did not do it justice. I've had NAV in most of our vehicles and always chosen integrated NAV's for their clean look. I was concerned this would not look that good and also heard the special mount might just be using suction cups. Thankfully, it does not.
They basically have a custom metal arm that comes off the tach and allows you to then attach the Garmin NAV. It's very clean looking and also provides power.
See more pics below. The NAV istelf is decent. I like the fact that it has batteries so I can hand it to the passenger to program while on the road. The BT speakerphone option is cool, bot not loud enough for me. Not sure that I will use a lof of the other featues, but the basic NAV stuff is as nice as any integrated NAV solution and the touch screen is easy to use...more pics in my gallery.
Thanks for the pics! Any ideas on where the power is taken from? Presumably it switches off with the key?
For those who want the integrated approach, this kit looks like a great way to go. The price is a little steep, but not really *that* out of line. I've seen several solutions for mounting stuff to the tach; there's an AMPS-pattern nüvi-compatible ball mount from ProClip for about $30; an additional 12v power adapter and windshield mount is available for another $30 or so. You're approaching $100 right there.
nope and that would be awesome, especially for the BT phone connection as the audio in sounds real good according to people I've called, but the speaker out is no good.
I'm sure you could make this happen, but it's not part of the standard install. I love my friend's M3. Radio turns down when he gets a call and it comes through his speakers. sweet stuff....
I did find the solution to have the audio routed to the drivers side speaker. once again Mikey from Newministuff.com to the rescue http://www.newministuff.com/new/shop...tshow&id=188// I am going to be ordering the MINI kit for my 03 and will be purchasing this adapter from mikey to get the full integration.
Very nice setup! It is much better looking and intergrated than I was expecting. Most of the time when a third party solution is offered litle is changed from the version han can be purchased retail. This is a setup that MINI has clearly looked into and implented in teh best OEM way they could.
I have a place to post them if needed. It's not fancy but it is web based and you would just select the file you want and download it. If interested just send to my open email (safe for posting anywhere). hunter99@mac.com
