FS:: Mini Cooper S Pepper White 6-Speed LSD
Year: 2006
Model: Hardtop
Price: $8000
Mileage: 97000
Color: White
Location (Region): West
sold
sold
sold
Up for sale is my favorite Mini Cooper I've owned. It's a 2006 Cooper S manual. I've meticulously taken care of this car in my ownership. I have most of the receipts from all four owners including myself (it's a stack). I also have the pre-purchase inspection from when I bought the car just over a year ago in Seattle. Mini was originally sold at Mini of Murray. It later went to Oregon, then Washington and I brought it back go Utah.
I have the original sticker for it. It comes with every package available.
-Cold Weather Package
Heated Seats
Heated Side Mirrors and Washer Jets
-Convenience Package
Universal Garage Opener
Auto Dimming Mirror
Rain Sensor and Auto Headlamps
-Premium Package
Auto AC
Dual Pane Sunroof
On-Board Computer
3-Spoke w/Cruise and Multifunction
-Sport Package
Dynamic Stability Control
Front Fog Lamps
Xenon Headlamps w/Power Wash
Rear Fog Lamp
Sport Suspension Plus
6-Speed Manual
Limited Slip Differential (LSD); This is a big deal.
Sport Panther Leather Seats
Center Arm Rest
Park Distance Control (Backup Sensors)
-Technology Package
Navigation
8-Speaker Harmon Kardon Sound System
Rubber Mats
-Modifications
Alta Cold Air Intake
Alta 15% supercharger Pulley
Alta 2% crank Pulley
Alta 19mm Sway Bar
Alta End Links
Megan Rear Control Arms
Nice Window Ting
Exhaust Resonator Deleted
LED Reverse Bulbs
European Mirrors w/Blindspot
Black Headlight Housing
Below are some of the maintenance items replaced within the last year. Most of them were preventive maintenance items. I know the common break points on these cars. Spent over 2K in parts.
-Single Mass Flywheel Conversion
-Clutch at 89,000 miles
-Slave Cylinder
-Rear Main Seal
-Transmission Seal
-Throwout Bearing Components
-Throwout Bearing
- Crank Sensor with O-ring
-Tons of gaskets and minor parts. Too many to list.
-Oil Pan Gasket
-Transmission Fluid
-Brake Fluid
-Supercharger Oil
-Coolant
-Drivers Axle
-Oil Filter Gasket
-Water Pump
-Water Pump Flange
-Temp Sensor
-Dogbone Mount
-Transmission Mount Inserts Poly
-Control Arm Poly Inserts
-Ball Joints
-Complete Suspension Refresh
-Power Steering Hoses (not cheap)
-Metal Coolant Flange w/New Thermostat
-Accessory Belt (15% and 2%)
-Crank Seal (Front Main Seal)
-Belt Tensioner
-Rewelded Header/CAT (common wear point)
-New Alternator
-New Battery
-Ignition Service Kit JCW
NGK BKR7EQUP spark plugs
Ignition Coil
Four Wire Set
Mobil 1 Oil and OEM oil filter
The last items were the most recent items. Just did the oil last week.
-There is much more that can be referenced on the receipts. I had the mirror caps and headlight rings painted to match the color of the car. Has the JCW look-a-like grille. Blacked out trim. I have also installed a roof rack and Mini Fini with locks. It comes with attachments for two bikes (can fit up to 4 bikes with the combined racks), tow hitch and the spare tire attachments. By the way I have an original spare tire/donut.
$9000
IM me for more info or more pictures.
Still for sale but no more price cuts. It's a hoot to drive. The power delivery is brilliant.
I'm in Holladay which is in Salt Lake City (towards the bench).
08-07-2015 05:55 AM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
