R56 Comfort Access will not release hatch
Hatch not releasing comfort access
The hatch will not pop when I push the button on the door handle or manually with my fingers. The only way it will release is pushing the hatch release on the fob.
Is not necessary to change it. You can open it and just replace the switch inside. It is a normal switch, like the one used in monitors with 4 pins. I had the same problem, trunk was not opening manually. Went to stealership (i like this term) and they quoted me 100 Euro. They say it cannot be opened cause is sealed. But it did opened it my self and just replace the switch. 2 $ fix.
It is strange that you did use a heat gun, cause when i opened mine, heat gun was not needed and no clips were broken. I will try tomorrow to make some photos when opening the trunk.
Here is the DIY for the trunk handles : There is Carbon fiber / Chrome / primed version. People swap
https://www.northamericanmotoring.co...rking-diy.html
If the gasket on the back that goes on the bottom and covers the micro switch is bad, cracked and causing water and salt to get into the switch, it will need replaced as a whole unit. Not a separate gasket. Just wanted to let you guys know.
The only important part is photo 7 in which you have to cut an silicon part. After you have finished changing the switch is good to put again silicon to not let water comes in. I did not used silicon and till now no problem with water coming in. Anyhow is better to do it. If you have questions let me know.
The last step is to clean your dirty hands and be happy.
100 pieces for $6.39 shipped.
http://www.ebay.com/itm/100Pcs-Tactile-Push-Button-Switch-Tact-Switch-6X6X7mm-4-pin-Coffee-color-/171576030680?pt=Motors_Car_Truck_Parts_Accessories&hash=item27f2ba75d8&vxp=mtr
I wonder if this is the right size though. That one is 6mm x 6mm x 7mm.
There's also 10 pieces for $3.79 in the 12mm x 12mm x 7mm size:
http://www.ebay.com/itm/10Pcs-Tactile-Push-Button-Switch-Tact-Switch-12X12X7mm-4-pin-/171573397241?pt=Motors_Car_Truck_Parts_Accessories&hash=item27f29246f9&vxp=mtr
