R56 Singing the blues!!
Singing the blues!! 2007 copper S
First let me say I have been stocking these forums for sometime looking for answers. Some have been very helpful for that I must say thanks. Let me say this first my spelling suxs sorry for my future misspelled words. Lol this is my daughter car 16 year old had to have a Mini Cooper . Car has 65000 miles and up to about a month ago problem free about 10,000 miles then it went south. I am not a Ase mechanic by know means but I pride myself on fixing most of my own cars. Here is the rub. Car started running really bad dyeing no power miss fire on every cylinder . First thought after reading a ton high pressure fuel pump or carbon on valves . First thing I did was get set up to do a walnut valve blasting since Mini Cooper of San Antonio wanted $900 something to do the job. Long story short got the valves cleaned still not running right better but not right. Took the car to Mini Cooper they changed the high pressure fuel pump under recall car got rid of the misfire codes but still runs bad. Said for $750 they would fix the valve cover leak I had $475 for the part $300 for labor.. Picked up the car changed out the part in 30 mins for $305 plus shipping. Car still runs like crap also had to change out a very over engineered thermostat housing due to a leak. Car still runs like crap at low rpms seems to be getting worse at high way speed it is ok has a what feels like a died miss from time to time. At low rpm it shakes no power and will die from time to time. 190 psi on every cylinder when I had the valve cover off thankfully some one has already change out the time chain with a new one that is good and tight no slack and a metal top rail as a guide. All hose clamps are tight and it is giving the following codes today p2178 p1497. Any help I can get would be great. Going to go back and take the intake manifold back off and look at the PVC device under it tonight . Also the car seems to go in and out of what I would call a limp mode when it is running right .
Thanks in advance for any help that is given .
Is this a Mini Cooper S or base model.
190 psi for every cylinder, that in itself is a great sign that at least you engine is in great shape! I will tell you what I tell everyone, when you get you intake walnut blasted don't stop there. You most likely have carbon buildup in your cylinders, valve faces and on top of pistons. I purchased an 07 MCS and had the walnut blasting performed and still my engine misfired until I ran several bottles of BG 44K which cleans the entire fuel system including the carbon in the combustion chambers.
How bad did you car run and what kind of codes did your car throw ? Just took the whole intake off again and do not see any thing that pops out at me hoses wise looked at the valves again and they look ok . This thing really runs bad at low rpms I can start to drive it again if that is what it takes have ran some lucas injecter cleaner and currently have chevron techron in the tank now.
Don't think I have the know how to do a smoke test or the tools. :( anybody out there from texas in Austin , San antiono or houston that would have this service at a fair price my dealership expectancies have not given my a very good taste in my mouth. Not looking for a free service but a fair price I know tools and skills are hard to come by.
mini cooper s
Ever have a look down through the spark plug hole? The carbon in your cylinders could explain why your readings are so high.
I'm glad to hear that your car is fixed! I assume that the cost of the timing chain replacement was covered under the campaign... correct?
gar56
11-15-2016 06:41 AM
