R55 Help installing rally lights.
the wiring is different and the brackets are different. In the end what you have is a $30 set of Hella clone lights with none of the parts needed to hook them up . . nothing special in the light's wiring themselves ... a + and a - . . .
If you can buy the factory harness from the dealer, I wouldn't. The factory setup is overly complicated IMO. You CAN hook up the wires for $30 in parts .. probably less. {some wire, a relay, a toggle switch ... some crimp connectors and shrink tube if you want to be fancy}
Bigger issue is/are the mounting brackets. You can buy a set for around $100 (check OUTMOTORING) or build a set if you can or know someone who can work with and weld steel . . .
Where are you? I've installed a bunch of sets on GEN1 and others and there are a million ways to go, but if anyone has tried to use the GEN1 harness on a GEN2 I'd ask WHY and would you you do it again!
If you don't believe me I can send you to online copies of instructions for installing both packages including wiring schematics . . . or find them at MINIMANIA.COM
ryGuyMCS
10-20-2015 02:24 PM
squawSkiBum
10-02-2015 09:21 AM
JHolland
08-24-2015 07:04 AM
