R50/53 2002 Mini Cooper S driver side door lock
Hi every one I'm posting here today because we just recently inherited a Mini Cooper s and we just got it back into running order and everything about tibia perfect, except for one or two things, like the door lock. Every time you get in the car and hit the lock switch on the console it locks the passenger and hatchback door but not the drivers, is this normal? Or is there a problem with the door lock? thanks!
Check the back of the toggle bank first to make sure the main harness plug did not come loose.
Then check the connection at the door the door lock. If its weak and only working it maybe the lock on its way out.
https://www.northamericanmotoring.co...-t-unlock.html
It possibly could be the door lock actuator going bad. Take a look at this NAM thread here. You can test it to make sure that the motor inside is in fact not turning. Post #3 has a great DIY that may be of assistance for the replacement. Here is another thread on NAM that may be helpful and a DIY at post #8. Good luck!
888.280.7799 | 6am - 5pm PST
Good luck! Let us know if that fixes your issue.
I think there is a sticky on the door lock problems here. It still sounds like it could possibly be the actuator. Make sure to inspect thoroughly and make sure that nothing is jammed.
07-16-2020 12:54 PM
Mini'mon
08-16-2015 04:15 PM
