R50/53 Gas light on - gauge is only slightly below a quarter tank?
I'd still run it down to past the red mark. I'd swear sometimes that the fuel needle goes below it's rest point when I start the car, instead of rising. You can go over 40 more easy miles when the range first shows (- - -). I've been doing this for 7 years and everything in the fuel system still works. Never ran the car out, though. I should push and find the absolute maximum range of the reserve.
Oh MY!! People still believing the gas gauge. That's gotta be the least accurate gauge in the car. After I first got my Mini, the gas light came on with 1/4 tank showing. I filled up PDQ, and took nearly 12gallons. With a 13+ gallon tank, that's not a lot of breathing space. I, personally, do not trust the computer telling me how many miles I have left. Better to fill early, and not be stranded. And, what does running out of gas do the pump? I'll let other deal with that issue....
You ever drink a soda? Then when it gets near empty its alot harder to get the soda is it not, tip the bottle, twisting the straw, more effort etc? Same thing applies to a fuel pump. Low fuel levels put stress on the pump.
These aren't precision instruments and there is likely some car-to-car variance when the light comes on - mine does it when it is slightly below 1/4 tank.
IOW, normal.
My gas gauge is fairly non-linear - it shows between full and 3/4 for nearly half the tank, but otherwise it is consistent and seems to track the last 1/4 pretty accurately, with a very small amount remaining when it finally bottoms out. That it behaves consistently and shows empty when it truly is empty is what is really important.
- Mark
IOW, normal.
- Mark
Modern fuel systems do a pretty good job of keeping the fuel input from unporting, even at very low fuel. So as long as the fuel pump is sucking fuel and not air, you're not doing your system any harm. You can run them low if you like, but you do want enough margin to be sure you don't run them dry.
- Mark
- Mark
Just developed a problem then found this old thread.
I was driving on the highway and looked at my gas gauge. It was just below a 1/4 tank. On the way to my destination was a gas station I was sure I had enough fuel to make it to the station. Wrong!!! I ran out of gas at just under a 1/4 tank and no indicator light. That is friggin embarrassing!
Is there a solution to this problem? Reason/new insight?
Having an astute command of the obvious has always been quite helpful. But on a more serious note, I never trust a fuel gauge and chasing a fix for fuel level accuracy even on the airlpanes I flew let alone automobiles never rendered a remedy that could be trusted hence I always pay attention to my fuel state on or off the ground. So,when the fuel gauge goes a notch below half on Our R53 I'm a looking to refuel. I have employed this practice for over fifty years and sofar so good. Just another obvious answer with footnotes.
Each time you fill up...you can note how many gallons of fuel you add, then compare it with what it holds..one warning...mpg varies... So don't get too confident...
Always fuel when you "think" you should have 50-100 miles left....
You should know your car enough to have an idea of city vs highway vs aggressive vs laid back driving to guess your mpg....
Fuel gauges have NEVER been very perfect....especially on a car that is about 10 years old....since repairs can get $$, simply changing you habits for free is a simple option.
I don't think anyone mentioned this yet...
The fuel pump is submerged in gas - which keeps it cool. When the fuel level drops below a certain point, the pump is exposed and heats up easily, which will kill it prematurely. To avoid this, you should always keep at least 1/4 tank of fuel in the car.
Another thing to think about is things gumming up in the gas tank. I had an issue with the gas gauge in my M Coupe. I added a can or two of sea foam to the tank and it must have removed some residue and the gas gauge has worked fine ever since. Others have had the same issue with the car and the fix was the same for most of them. Just food for thought.
07-16-2020 12:54 PM
dchang0
08-10-2015 03:37 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
