Navigation & Audio Disable, Turn off, Navigation System?
Old 02-01-2016, 09:18 PM
Jeff Wallen's Avatar
Jeff Wallen
Jeff Wallen is offline
I have an 05 S with the nav screen and want it to not load when I turn the key. Is there a way to disable the nav screen without messing anything up? I have looked high and low to no avail. I would swap to the large speed O but research has turned up a no go for that. So if I can at least shut it off that would be a plus.
Old 02-01-2016, 11:09 PM
rkw's Avatar
rkw
rkw is offline
Try pulling fuse F22 (15A). It should disable the Nav computer without affecting anything else.
If it doesn't work or has unexpected side effects, you can disconnect the screen itself (or even remove it entirely). The Nav system will still be running, just nothing appears on the screen.
Item # 2:
Old 02-01-2016, 11:13 PM
Jeff Wallen
Great input! Thanks! I want the screen off and the fuel gauge working, so I will try the fuse first to see what happens.
Old 04-26-2016, 12:13 AM
alistaircookie's Avatar
alistaircookie
alistaircookie is offline
This has been very helpful advice to totally disable the NAV screen. But what if I want the screen default to just be off instead of on?
Does anyone know if it's possible to set the NAV screen to be off when you turn on the car, but still able to be turned on at the push of a button?
Old 06-29-2016, 05:04 AM
Stadler's Avatar
Stadler
Stadler is offline
Sorry I know this is an old thread, but has anyone figured out how to start the cooper with screen off? Able to push menu and have screen on?
Old 06-29-2016, 08:33 AM
rkw's Avatar
rkw
rkw is offline
I no longer have my MINI to check, but I thought there is a display on/off option. Look on the Settings screen, and also the diagnostic screen (while in the Settings screen, press and hold the menu button for 10 seconds).
Chili the red
02-03-2016 02:06 PM
Chris Frillman
02-01-2016 01:30 AM
Toolz
01-30-2016 05:56 PM
ti22fjc
01-29-2016 10:44 AM
DUDLEY13
01-28-2016 09:51 AM
Quick Reply: Navigation & Audio Disable, Turn off, Navigation System?
