Navigation & Audio disable/hide satellite input?
Old 09-04-2014, 05:38 PM
keen's Avatar
keen
keen is offline
folks,
is there a way to get rid of the satellite radio selection on the base stereo? I'm OK with disassembly and disconnection if that's what it takes, but it does seem like this should be configurable!
I have zero interest in sirius, and I keep finding myself accidentally switching to it.
thanks!
..david
Old 09-05-2014, 11:51 AM
Kevdog's Avatar
Kevdog
Kevdog is offline
I bet it would be as simple as a few settings in NCSExpert.
It would probably start with removing 655 from the VO. 655 is the option that says you have a satellite tuner. Then you would have to find any module which refers to the tuner, and set it to nicht_aktiv. FWIW I searched all of my modules and couldn't find a line which refers to the tuner.
I think CHAMP or in my case HAMP is the stereo module, but mine has almost nothing in the TRC. Try removing 655 and see what happens!
Old 09-05-2014, 01:15 PM
keen's Avatar
keen
keen is offline
thanks for the details - as someone who hasn't yet touched NCSExpert, what's the risk level of trying a change like this?
Old 09-06-2014, 05:27 PM
Kevdog's Avatar
Kevdog
Kevdog is offline
NCSExpert has a HUGE learning curve. Getting a working system and cable is the harder part.
As long as you knew what you were doing; had a known working system, properly removed 655 from the vehicle order and defaulted CAS and FRM, I think the risk is very small. I had to add rear fog lights to my VO as a beginner to coding and it wasn't a big deal.
Removing satellite from the VO would take all of 5 minutes for me to "test", it's just not something I'm willing to play with. I really should though as my satellite is just an input I have to pass through every time too!
Old 10-22-2014, 05:25 PM
keen's Avatar
keen
keen is offline
to update: Yep, remove $655 from the VO (and FA_WRITE to CAS/FMR), and SG_RESET 2RAD (SG_RESET is the only option that works for at least my '13 GP and other later build cars - 2RAD isn't read/write from the CAN bus anymore but will take a reset.
Old 10-23-2014, 11:04 AM
Kevdog's Avatar
Kevdog
Kevdog is offline
Glad that worked out for you!
eliseo1981
11-02-2015 11:24 AM
pglgp1292
10-05-2015 06:47 PM
simo711
10-01-2015 05:36 AM
Levers_and_Gears
09-28-2015 04:42 PM
BossyR56
09-28-2015 11:33 AM
Quick Reply: Navigation & Audio disable/hide satellite input?
