Navigation & Audio X9331 direction
Old 04-15-2014, 08:36 AM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
X9331 direction
Can't seem to find the answer here:
What direction is the signal flow in the X9331 connector?
Meaning which side of the connector is from HU, and which side is to speakers?
Old 04-18-2014, 04:52 AM
s0n1c's Avatar
s0n1c
s0n1c is offline
The female side of the connector is coming from the HU. I just recently was splicing it apart and that's the side I worked with.
Old 04-18-2014, 06:56 AM
TVPostSound
I just found this, that seems to be male from HU to female into connector.
Im now confused!!??????
Old 04-18-2014, 07:11 AM
s0n1c's Avatar
s0n1c
s0n1c is offline
Now you're making me second guess myself. I know I was working on the female side of the connector...and I spliced in my own amp (similar to what that connector you posted does)...but I could be wrong about the direction of flow....what I do know is that what I did worked...so I guess I should rescind my statement and suggest you go by what the picture suggests. I'm more likely to be wrong.
Good find! If I have time, I'll double check what I was doing and post my findings...
Old 04-18-2014, 11:17 AM
Kevin@Integral Audio's Avatar
Kevin@Integral Audio is offline
The female/socket side is signal from HU. Ignore that picture - it was just a quick (and not very good) picture for website. But it was taken of an initial production run from long ago where the input and output were transposed on the production drawings by the supplier.
Never expected anyone would be looking at it so closely....
Old 04-18-2014, 03:58 PM
TVPostSound
OK cool.
My plan is to pop in the IA loom, (whenever stock is back) prior to plugging in the Alpine retrofit amp loom.
Send a low level signal to a powered sub.
Old 04-19-2014, 04:12 AM
s0n1c's Avatar
s0n1c
s0n1c is offline
This makes me feel a lot better! I was racking my brain pretty hard after looking at that picture wondering where I went wrong...and if it was wrong, how was it working...and so on...
minimofo
12-26-2015 12:03 PM
FatherG
10-03-2015 05:06 PM
simo711
10-01-2015 05:36 AM
tristanwelch95
09-30-2015 08:58 AM
Emnotek
09-29-2015 07:37 AM
Quick Reply: Navigation & Audio X9331 direction
