JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Can stock bov handle increase power?
Old 09-12-2015, 07:32 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
So I have done quite a few upgrades on my car. 09' JCW and my question is can the stock BOV on my JCW handle the power increase?
Phil
Old 10-07-2015, 11:32 PM
johnso56's Avatar
johnso56
johnso56 is offline
Depends on what upgrade you did. If you did a tune, you better change your BOV or at least upgrade your bov spring to the Alta spring (for N14 engine) like I did
Old 10-08-2015, 03:14 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
John I'm running intake,bigger IC,EXHAUST,HOT SIDE DP, STAGE 1 on my accessport 92 octane or above and FMIC. I'm still using the stock BOV. I have a 09 JCW I'm not sure if the BOV is higher performance in that model.
Phil
Old 10-08-2015, 07:13 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
It can handle some boost increase but can become the weak point at higher boost.
We recommend going with the Forge recirc valve kit as it can handle over 20lbs of boost and reacts much faster
http://www.waymotorworks.com/forge-blow-off-valve.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 10-08-2015, 07:46 PM
johnso56's Avatar
johnso56
johnso56 is offline
Well in my case does my Alta spring upgrade for the stock BOV helps? I only got manic tune stage 1+ with bigger IC and exhaust (didn't upgrade the DP)
Old 10-09-2015, 08:02 AM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
Thanks I really don't need to here that loud woosh sound. I think I here a small sound from the stock one. Is it easy to install. And what are your thoughts about just changing the spring ?
Phil
Old 10-13-2015, 09:12 PM
Systemlord's Avatar
Systemlord
Systemlord is offline
Phil
There's a BOV that vents in the engine bag that's loud and then there's the recirculation valve that you're supposed to use.
Old 10-13-2015, 09:29 PM
Indimanic's Avatar
Indimanic
Indimanic is offline
Either GFB or the ALTA units have worked well for my tuned R56 JCW. I run 25 psi of boost and both close rapidly Need a vacuum source for the ALTA. It's been my experience that the FORGE spacer that vents to atmosphere caused CEL and 1/2 power codes (not the valve setup itself but the spacer). The DME needs to see that air back into the intake. I've read that some folks have never had a problem with the spacer but I did.
07-16-2020 12:54 PM
theunlimitedone
08-31-2015 08:17 PM
larmini
08-09-2015 10:28 PM
Ambient Thermal Management
08-07-2015 12:27 PM
PelicanParts.com
08-04-2015 02:45 PM
Quick Reply: JCW Can stock bov handle increase power?
