JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Crank Position Sensor replacement ??
Old 01-27-2015, 08:49 PM
Bob Keber's Avatar
Bob Keber
Bob Keber is offline
Do you think I need to put Draco (03 JCW) in Front End Service Mode to get to the sensor, or could I take out the air intake and Supercharger cooling unit.. sorry drawing a blank on its name (Long Day) ....and then be able to reach the Sensor that way?
Old 01-28-2015, 06:36 PM
NC TRACKRAT's Avatar
NC TRACKRAT
NC TRACKRAT is offline
Go the Service Mode route. Not that big of a deal.
Old 01-29-2015, 01:07 AM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
If all you need to access is the sensor, you can use the 'Rudy Method', which consists of removing the lower motor mount, and using a ratchet strap to pull the engine back. It's a bit tight, but takes a lot less time. See thread here.
Old 01-30-2015, 12:00 PM
nkfry's Avatar
nkfry
nkfry is offline
Service mode will allow you the most access to the sensor, and allow you to clean more of the area (if the sensor was leaking). I would recommend putting a small bead of black RTV around the base of the sensor prior to installation to keep the sensor from leaking in the future.
But the aforementioned Rudy Method is going to be a touch quicker, if you're looking to save time.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 02-07-2015, 04:25 AM
Kahnfucious's Avatar
Kahnfucious
Kahnfucious is offline
I did the crank position O-ring via rudy method it's very tight and makes it very tough to clean all the mess off but it works. Pretty quick too...just be forewarned getting that electrical connector off will be next to impossible with this method...you can't really see or get your hands up there well enough. You can pull it out with the connector still connected and try from there...I just left mine connected but you are replacing the sensor.
Old 02-08-2015, 10:53 PM
Eric_Rowland
Even letting the sensor hang down on the wire where I could see it did not enable me to figure out how to remove it. If someone knows the trick, I'd love to hear it.
Svejk
02-24-2019 12:18 PM
Motown
04-20-2018 09:31 AM
squawSkiBum
10-02-2015 09:21 AM
Minibeagle
08-13-2015 10:00 AM
pocketmaster
08-11-2015 07:36 AM
Quick Reply: Crank Position Sensor replacement ??
