How To DIY Requests....
#27
All you gotta do is pull it out from the grill. If you're afraid of breaking it then remove the entire grill and go from there.
In order to remove the grill, you will need to pry the top 4 expanding rivets ( in front the grill) and press the 4 bottom clips (behind the grill) then pull it out from the bumper.
It's pretty much self-explanatory once the grill is removed.
http://www.realoem.com/bmw/showparts...20&hg=51&fg=15
I also found this 'how to' in my searching:
https://www.northamericanmotoring.co...56s-guide.html
Thanks again!
#30
2 easy ones here...
I have 2 requests if possible:
1). Valentine One install on here is great. But, how/where do I install the remote display? Sitting in the car I can't think of a good place to put it. Any ideas?
2). Is it possible to install HIDs in the factory fog lamps? I have a 2010 MCS.
Thanks in advance for any help you can give me.
#31
[QUOTE=AstroBlackBeast;3066288]I have 2 requests if possible:
yes it is, but you will need resistors because there is not enough power to power both lights. one will stay on while the other flickers and goes out
#33
I'll be doing my own tire rotations on my 2010 R55 and am having a hard time finding a full set of very specific instructions on how to lift the entire car up using a jack and jack stands; I've never done it before.
I need step-by-step precise instructions that detail everything from the initial jacking up of the car to placing the jack stands under it, including exactly where to place the jack and all of the jack stands.
Thanks!
Thanks!
#34
#36
#37
http://www.cravenspeed.com/product_images/instructions/crmc-0046-r56-shiftwell.pdf
#39
I just found out from a dealership that my thermostat housing is cracked and slowly (thankfully) leaking coolant. Vehicle is still drivable however I need to top off the expansion tank from time to time. Dealership quoted $410.00 repair job, part is $106.27 (realoem.com) and I'm confident in my skills in replacing the unit myself if I had a decent set of instructions.
Have anybody replaced their thermostats on a R56 MCS and have a decent writeup?
Cheers.
Cheers.
#43
I believe I may have an exhaust leak. I'd like to see a write up on replacement of ALL exhaust related gaskets on an r56 MCS. From the engine block > exhaust manifold > Turbo > Down Pipe/CAT. unsure if there is anything special I need to do/remove prior to getting access to those items.
I'd also like to put my vote in on how to properly lift the car onto 4 jack stands.
And another vote for a guide on a proper coolant flush.
I really wish we had a good mechanics reference book to have on hand for this car.
#45
https://www.northamericanmotoring.co...oof-rails.html
#46
[QUOTE=stinkytofu;3083805]where can i get resistors for the fog lamps? and do you know how to get inside the actually fog lamp to get the light. cant seem to figure it out .
#47
Oil change indicator?
Is there a way to reset the indicator in the dash when you do your own oil changes? I do the oil change around 5000 miles and it is too far to take it in every 15000 to have the dealer do it. I couldn't find any thing about reseting the computer with a search.
http://r56mini.com/tisdocuments/
Go there and look for CBS reset instructions
Thanks, I'll give that a try!
