Recommendation: Trusted Mini Mechanic in Greenville, SC
I wanted to post this recommendation for any one needing repair work on their Mini. If you live anywhere near Greenville, SC I highly recommend Brent's work. He was a Mini dealer tech for several years and is doing independent work out of his home garage. He has a great source for parts and he has a lift and OBD diagnostic tools for Mini, BMW, and Mercedes cars. From what I saw of his tools and work he can perform any repair you need.
This past weekend he got my A/C working again by replacing the A/C Clutch Coil versus the whole compressor. He never had to open the system which saves alot of time and money. He uses a great common sense approach to keep your repair costs down versus the dealers "make all we can make' attitude". I drove 90 minutes and it was well worth the drive time instead of paying Century Mini $1,500 for the same repair. You can learn alot about your Mini from him as he works on your car which is great!
You can contact Brent at bbprevatte@charter.net
David Wilson (11-04-2021)
MINI clutch
Also if anyone has any other recommendations in case Brent doesn't respond that would be highly appreciated! Thanks!
MINI mechanic
Thanks Jim! I spoke with Brent and he was extremely knowledgeable - gave me several bits of advice on how to proceed...... Thanks for all the help!
MINI mechanic in Greenville area
When I last spoke with Brent he was all in for getting my MINI repaired - I don't live there and had to get it looked at same day so I missed out and it cost me some dollars and time as a result. He did call me back the following day but I had already committed to another local repair shop - in retrospect I should have just waited but I did not know if I was going to get a response as I had never dealt with him before - if you can wait a day it will be worth you r time I believe...
would you mind please dm me with the contact info for Brent? I’ve called beemers and benz and was told they don’t work on minis… but he sounds like a solid mechanic. TIA, Shannon
07-16-2020 12:54 PM
phrza81
10-10-2015 11:37 PM
