Electrical Auto Sport Button
#26
Alright... I guess I will go into more detail.
The module with the fogs, sport button, etc. is a digital module with a pigtail - I've physically removed that, which I suggest none of you do...
The signaling between that panel and the BCM passes through the HVAC control, which converts LIN to CAN. The switch is not physically SPST -- the actuation causes a LIN signal to be sent, which is them passed through as a CAN signal.
The ONLY way to do something at the switch level would be to physically de-solder the switch connection (which is epoxied to the board by the way) and physically install a device to the momentary ground before the PIC.
Then you could setup a relay with 12v signaling to ground the circuit, etc. That is way above everybody's pay grade, but you can try if you'd like.
Trust me when I say there's a LOT of frustration in front of you if you'd like to continue with it. We just said screw it...
I believe the procedure is not the same as the R56, since the connection is LIN, right?
Can you provide a schematic/diagram? Is the codding the same?
Thank you
smdmini
10-07-2019 06:05 AM
molala
10-02-2015 01:53 PM
