Mini Cooper 2007-2013: Recalls and TSBs
As with most cars on the road today, there are a number of recalls and TSBs for the Mini Cooper that you should be aware of. This article has all the info you need to keep your ride safe and running right.
By Kate Halse - August 4, 2016
This article applies to the Mini Cooper (2007-2013).
Recalls and technical service bulletins (TSBs) are all over the news these days, scaring consumers with dangerous situations that could seemingly strike at any moment. While many times these incidents are isolated and rare, they also represent fixes that should be completed for safety's sake. While recalls are typically issued in times when safety is compromised, TSBs typically cover parts that should be replaced or fixes that should be completed to avoid premature failure or problems down the road. Keep reading, as we'll cover the recalls and TSBs that relate to the Mini Cooper.
Recalls and TSBs
Timing Chain Tensioner
Perhaps the most famous problem with the Mini Cooper is its timing chain tensioner, purported to be so good they didn't require service, instead leading to premature engine failure in some instances. Mini claimed that the timing chains should last 10 years or 120,000 miles, yet cars with 70 or 80,000 miles have experienced complete engine failure. After issuing a TSB back in 2008, BMW refused to compensate owners for engine repairs until it agreed to settle a lawsuit brought against it back in 2015.
Faulty timing chain tensioner in MINI Cooper
Figure 1. Faulty timing chain tensioners can lead to premature engine failure.
Water Pump Circuit Board
BMW issued a recall for almost 89,000 2007 to 2011 Mini Coopers in lieu of an electronic circuit board that could overheat, and in some instances, even cause a fire. The circuit board controls the electric auxiliary water pump which cools the turbo. Owners were notified of the recall, but if you own one of the affected models listed below (especially if you bought your car used), you certainly want to check and make sure your car has been repaired properly.
  • 2007-2011 MINI Cooper S
  • 2008-2011 MINI Cooper S Clubman
  • 2009-2011 MINI Cooper S Convertible
  • 2011 MINI Cooper S Countryman
  • 2009-2011 MINI John Cooper Works
  • 2009 MINI John Cooper Works Clubman
  • 2010-2011 MINI John Cooper Works Convertible
Overheating circuit board in MINI Cooper
Figure 2. An overheating circuit board has resulted in a fire for some Mini owners.
Other Recalls and TSBs
Here is a complete list of the recalls TSBs for the 2nd gen Mini Cooper. To check and see which recalls apply to your specific model, you can enter your car's VIN here to get an accurate listing.
00 Maintenance and General Hints
SIM 00 02 02 MINI Operating Fluids
SIM 00 02 02 Attachment MINI Operating Fluids Attachment
SIM 00 02 07 New Vehicle Preparation and Maintenance Requirements
SIM 00 03 07 Condition Based Service
SIM 00 03 07 CBS R56 CBS SERVICE ITEMS OVERVIEW
SIM 00 03 07 Symbols CBS symbols
SIM 00 02 09 CBS Service Maintenance Substitute Checklist
SIM 00 03 09 TeileClearing (Enhanced Technical Support)
SIM 00 08 09 MINI Product Content Changes
SIM 00 08 09 Attachment Attachment to SIM 00 08 09
SIM 00 01 10 Quality Feedback Awards
SIM 00 02 10 2011 Model Year New Vehicle Preparation and Maintenance Requirements
11 Engine
SIM 11 01 07 Service Action: Retrofit of Crankcase Ventilation Breather
SIM 11 02 07 Rattle Noise from Engine
SIM 11 04 07 Testing Induction Systems Using the VACUTEC® Smoke Machine
SIM 11 01 08 N12 and N14 Engine Bedplate Sealing
SIM 11 02 08 Knocking Noise from Vacuum Pump
SIM 11 03 08 Turbocharger Failure - Oil Supply Line Blockage
SIM 11 06 08 MINI Emblem Missing from Valve Cover
SIM 11 07 08 Crankcase Ventilation System Specification
SIM 11 01 09 N14 Replacement Cylinder Head Cover
SIM 11 02 09 TeileClearing for Engine Components
SIM 11 03 09 Whistling Noise from the Water Pump Area
SIM 11 02 10 Incorrect Crankshaft Central Bolt Torque
12 Engine Electrical Systems
SIM 12 02 07 Alternator Battery Positive Cable Connection
SIM 12 08 07 N12 and N14 Engine Oil Service with CBS4
SIM 12 09 07 TeileClearing (Enhanced Technical Support) for DME
SIM 12 12 07 Service Engine Soon (MIL) is On - Fault 2FAC: Engine Switch-off Time
SIM 12 01 08 Service Engine Soon Lamp Illuminated: Lean Mixture Faults Stored in DME
SIM 12 02 08 Service Engine Soon Lamp Is Illuminated: DME FC 276A
SIM 12 02 10 Cooper S with N14 – Diagnosis for Misfire Faults
SIM 12 02 10 Cleaning Procedure N14 Direct Injection and Combustion Chamber Cleaning Procedure
13 Fuel Systems
SIM 13 01 07 Fuel Injection and Induction System Cleaning
SIM 13 01 07 Procedure C SIM 13 01 07 - PROCEDURE C - N12 Engine
SIM 13 01 08 Fuel Odor from the Engine Compartment
SIM 13 01 09 Removing and Installing N14 Fuel Feed Line
16 Fuel Supply Systems
17 Cooling Systems
SIM 17 01 07 Long-Term Antifreeze/Coolant: Maintenance, Repairs and Replacement Requirements
SIM 17 02 07 Electric Cooling Fan Runs After Engine Is Shut Off
18 Exhaust Systems
SIM 18 01 08 Safety Recall Campaign 08V-657: R56 Cooper S – Replacement of Tailpipe Extensions
SIM 18 01 09 Voluntary Emissions Recall 09E-A01: R55 and R56 N12 - Catalytic Converter Replacement
SIM 18 01 10 N18 – Cold Start Exhaust Rattle Noise
SIM 18 02 10 N18 – Cooper S Exhaust Popping Sound
21 Clutch
SIM 21 01 07 Honking and/or Howling Noise during Downshift
SIM 21 01 10 Removing and Installing Self-adjusting Clutch (SAC)
SIM 21 01 10 Attachment Self-adjusting Clutch Removal and Replacement Procedure
22 Engine and Gearbox Suspension
SIM 22 01 08 Knocking Noise from the Front of Vehicle
23 Manual Transmission
SIM 23 01 08 R55, R56 with Manual Transmission - "Stiff" Diagonal Gearshift
SIM 23 02 08 TeileClearing for Getrag Manual Transmissions
SIM 23 03 08 MINI with Manual Transmission - "Stiff" Diagonal Gearshift
24 Automatic Transmission
SIM 24 01 06 AISIN Automatic Transmission Repair and Replacement Information
SIM 24 01 07 Fluid Leak From Automatic Transmission
SIM 24 01 08 R55, R56, R57 with F21 Transmission – Warning Light Illuminated with FC A0B6
SIM 24 01 10 TeileClearing for AISIN Automatic Transmissions
31 Front Axle
SIM 31 01 07 Knocking Noise from Front Axle
33 Rear Axle
SIM 33 01 07 Knocking Noise from Rear Axle
SIM 33 01 10 Clicking Noise from Rear Suspension on Uneven Road Surface
51 Body Equipment
SIM 51 08 07 Rattle from the Instrument Panel
SIM 51 09 07 Water Leak from the Front Doors
52 Seats
SIM 52 01 08 Seat Heater Feels Too Warm
SIM 52 02 08 Rattle from the Rear Seat Backrest
SIM 52 01 10 Squeak from Rear Seat Backrest
54 Special Roofs
SIM 54 01 07 Wind Noise from Sunroof
SIM 54 04 07 Sunroof Sunshade Opens Spontaneously
SIM 54 03 08 Sunroof Will Not Open at High Temperatures
SIM 54 03 08 Lubrication Procedure Sunroof Lubrication Procedure
61 General Electrical Systems
SIM 61 05 07 Bad Ground Causes Various Electrical Problems
SIM 61 08 07 ELV Does Not Release
SIM 61 10 07 Service Action: Repair or Retrofit IBS Battery Sensor
63 Lights
SIM 63 01 09 Headlamps Flicker and Move Up and Down by Themselves
SIM 63 03 09 Headlamp Moisture: Fault Diagnostics
SIM 63 01 10 Check Control Message but Lights are Operating Normally
64 Heating and Air Conditioning
SIM 64 02 08 Driver Footwell Area Becomes Hot
SIM 64 02 08 Procedure Procedure for installing insulating foam
SIM 64 01 10 Air Conditioning Compressor Excessively Loud
SIM 64 01 10 Attachment A/C Compressor excessively loud REPAIR PROCEDURE
65 Audio, Navigation, Monitors, Alarms, SRS
SIM 65 01 08 Alarm Sounds After Locking Vehicle
SIM 65 02 08 Alarm Activates by Opening the Tailgate Via the Remote
SIM 65 03 08 Service Action: Real Time Traffic Information Not Available
SIM 65 05 08 Service Action: Check SVS Function
SIM 65 06 08 CD Doesn't Eject
SIM 65 07 08 CCC: CD Player Bezel Rattles over Bumps
SIM 65 07 08 Procedure SIM 65 07 08 Procedure to repair rattle
SIM 65 08 08 Anti-theft Alarm Is Triggered Unexpectedly
SIM 65 11 08 Audio Complaints Relating to Audio CD/Audio DVD Drive
SIM 65 01 09 USB Audio Interface
SIM 65 02 09 HD Radio™ - Functionality and Diagnosis
SIM 65 04 09 iPhone Doesn't Charge When Connected To The USB Audio Interface
SIM 65 01 10 CCC - "Please Insert Navigation DVD" appears on CID
SIM 65 05 10 iPod/iPhone Has Extremely Poor Audio Quality and/or Is Not Recognized
SIM 65 06 10 Navigation System Has Missing or Incorrect Road Map Data
SIM 65 07 10 Real Time Traffic Information
SIM 65 07 10 Attachment A Real Time Traffic Information FAQ
SIM 65 08 10 CD Changer Is Inoperative and All LEDs Are Flashing Rapidly
SIM 65 09 10 Bluetooth, Hands-free and USB Audio Functions Are Delayed After Vehicle Start
SIM 65 10 10 Radio Display Errors
SIM 65 12 10 USB Audio Output Is Inoperative or Intermittently Interrupted
71 Tools and Accessories (Engine-Chassis)
SIM 71 01 07 Sunroof Emergency Operation Tool Eliminated
SIM 71 01 09 Recall Campaign 09V-474: Inspect Tire Information Placard
Related Discussions and Site
