Bridgestone RE71Rs/NM Re05s 17x7.5 Rims/ECS 10mm Spacers
Old Jul 21, 2019 | 07:50 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
Finally got the245s mounted in place of the 225s on 7.5" Rims...needed 10mm Spacers to clear the front strut. There are still a few small adjustments/trimming/alignment changes to be made...
but they will fit and I hope increase grip for future AutoXs coming up. They feel great...They are a bit taller and wider but I think both those things will benefit me in an AutoX...Width for Grip and
Height for Gearing (want to stay in 2nd gear on most courses. Track width is basically at it's maximum with allowed mods...Just one note...Although the NM Wheels do swap out perfectly for
stock wheels, the ECS Spacers don't fit perfectly. I had to machine down the beveled edge just a bit to get the wheels to sit flush on the NM Wheels.
Old Nov 17, 2019 | 04:45 PM
Blackcoffee's Avatar
Blackcoffee
I’m very interested to know if the increased tire size helps or hurts your times, as the increased weight and drag could outweigh cornering grip.
Old Nov 20, 2019 | 03:17 PM
Beemerchef's Avatar
Beemerchef
Question for you and by the way, it looks good...
I don't race, only drive spirited since my 1966 [bought in 1966!] Austin Cooper S and now 2018 JCW.
Important to mention I have 18" stock wheels with 225 tires.
Since I am pushing close to 300hp and feeling the handling is not quite up to par [Yokohama Advan tires NON run-flat!] and not wanting to spend on a new suspension, I have gone the route of Cravenspeed Big Pair and NM Engineering engine tie-bar. Is it helping? Maybe!!!
But, I am thinking also spacers such as yours... 10mm front and maybe 15mm rear? The rear fender has a short lip inward.
With your knowledge and mainly considering I have 18" wheels, do you think I would rub?... I am trying to avoid getting their test kit [non drive-able].
I appreciate your feedback...
Thank You
As I am obviously interested in installing spacers I had not thought about your comment which has a strong point.
Old Nov 21, 2019 | 09:55 AM
Juice84's Avatar
Juice84
Darby, did you keep these? I thought i saw in another thread you went back to 225s.
Darbys2019MiniJCW
Jul 21, 2019 07:41 AM
MikeMJCW
Wheels/Tires/Brakes
Apr 9, 2019 09:41 AM
TomL1013
Jan 27, 2019 10:26 AM
vicj
May 22, 2013 04:26 AM
sleekbass
May 17, 2011 12:11 AM
