Looking for NM Engineering RSe05 17" wheels
Looking for a set of NM Engineering RSe05 17" Wheels, Part #nm.880503G. NM only has 1 in stock. They said most of the places selling them don't stock the wheels, most just drop ship from NM.
If I can't find a set soon, anyone know of any other 17" wheels that will clear the JCW brakes without using spacers or hub rings?
I just got the only set of Gunmetal 17x7.5 the other day...they are arriving today in Texas.
Just got new Bridgestone RE71R's 225/45/17's mounted on the great looking NM 17x7.5" wheels...mounted them on the Mini with 5 mm spacers all the way around...They Look FANTASTIC
Do you have any rubbing issues with the 225s with the 5mm spacers?
Before I added the rear adjustable control arm, I did hit the plastic outer flair just a tad if I hit a serious bump...but since I lowered the Mini and added the Control Arm...no issues even AutoXing. Once I get the Vorshalg Front Camber Plates, I am going to try to fit 245s all the way around...
I've been looking at the NM Eng. RSe05 or NM Eng. RSe52, which it looks like you may be running. Right now, I'm still looking. I've only had the car for a couple of weeks. I need to figure tire size and weight tradeoff.
I'll keep the stock wheels for winters, and I'll run a narrow HAKKAPELIITTA. Either a 205 or a 195, if I can find the right ratio.
suprtran
12-11-2014 10:39 AM
